Okay, so:
SRAM Tests:
0 Ohm, default frequency: No Programming
240 Ohm, default frequency: Programming
0 Ohm, (0x0001) frequency: No Programming
240 Ohm, (0x0001) frequency: No Programming
0 Ohm, 1MHz (0x0005) frequency: No Programming
240 Ohm, 1MHz (0x0005) frequency: No Programming
0 Ohm, (0x0010) frequency: No Programming
240 Ohm, (0x0010) frequency: No Programming
0 Ohm, (0x0050) frequency: No Programming
240 Ohm, (0x0050) frequency: No Programming
I don't know how many different combinations I should try before deciding we need to try a different route or... not sure.
![Tweak :-/O](https://www.eevblog.com/forum/Smileys/default/smiliey_cal.gif.pagespeed.ce.yYMcAvxBJk.gif)
