Hi, I would like to seek some help in DSP Programming.
I'm using simple coding to turn on (HIGH) and off (LOW) 2 PORTS (PORTB (GPIO 39-47) and PORTC (GPIO 64-87)) GPIO in TMS320F28335 using CCS Composer Ver. 11.
The coding is as follows:
#include "DSP2833x_Device.h" // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h" // DSP2833x Examples Include File
void configtestled(void);
void main(void)
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2833x_SysCtrl.c file.
InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP2833x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio(); // Skipped for this example
InitXintf16Gpio(); //zq
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example. This is useful for debug purposes.
// The shell ISR routines are found in DSP2833x_DefaultIsr.c.
// This function is found in DSP2833x_PieVect.c.
InitPieVectTable();
configtestled();
GpioDataRegs.GPBDAT.all = 0xFFFFFFFF;
GpioDataRegs.GPCDAT.all = 0xFFFFFFFF;
DELAY_US(50);
while(1)
GpioDataRegs.GPBDAT.all =0x00000000;
GpioDataRegs.GPCDAT.all =0x00000000;
DELAY_US(500);
GpioDataRegs.GPBDAT.all =0xFFFFFFFF;
GpioDataRegs.GPCDAT.all =0xFFFFFFFF;
DELAY_US(500);
EALLOW;
GpioCtrlRegs.GPCMUX1.all = 0x00000000; // All GPIO(C)s are GPIOs (GPIO 64 - 79)
GpioCtrlRegs.GPCMUX2.all = 0x00000000; // All GPIO(C)s are GPIOs (GPIO 80 - 87)
GpioCtrlRegs.GPCDIR.all = 0xFFFFFFFF; //All GPIO(C)s are outputs
GpioCtrlRegs.GPBMUX1.all = 0x00000000; // All GPIO(B)s are GPIOs (GPIO 39 - 47)
// GpioCtrlRegs.GPBMUX2.all = 0x00000000; // All GPIO(B)s are GPIOs
GpioCtrlRegs.GPBDIR.all = 0x0000FFFF; //All GPIO(B)s are outputs
EDIS;
// No more.
The funny phenomenon that I'm facing is that when I compile and run the program only GPIO 39-47 in PORTB and GPIO 80-87 in PORT C are able to change states between HIGH (on) and LOW (off) while GPIO 64-79 in PORTC pins are always at LOW (off) state.
Kindly give me some advice on how can I solve this issue.
Thank you in advance.
Regards
Chris
