Author Topic: GD32F303 - interrupts do not work when Stop low power mode is entered  (Read 768 times)
Offline vlado.valkTopic starter
  • Country: bg
When GD32F303 enters STOP low power mode, external interrupt on pin PA0 or any other interrupt(SPI, Uart etc) do not work and
do not wake up the MCU
Offline thm_w
  • Non-expert
What is the code you used to enter STOP mode?
SPI or UART won't be an option as a wake source, PA0 should work though.
https://controllerstech.com/low-power-modes-in-stm32/
  • Country: bg
I use the standard firmware library and exit stop mode by external interrupt(Falling edge) on PA0, but MCU does not exit sleep
Offline Psi
are you sure you are entering sleep/stop mode with both the GPIO interrupt and global interrupts enabled?
Offline thm_w
  • Non-expert
Post the actual code you are using to do that.
