Thank you! I got ISE 13.1, that is bigger than ISE 10.1, it seems 9Gbyte, too much for me!
I installed it into an external hard drive (just in order to evaluate it, i do not like having program running in usb external drive)
cause i have enough space to accommodate it to the internal drive
(i also have Labview, NI multisim and many more applications installed, plus linux in the second partition)
Also i got
ModelSim PE Student Edition by Mentor
it seems a funny simulator, i have been toying with if for 2 hours around easy examples and my old vhdl code
and i am happy with it, it is easy to use, intuitive, and it uses only 300Mbyte
About the license … well it requires a fixed node license, which means you have to register your student license
from the machine you want the program installed to, and you can't change the machine without repeating the license validation
not too bad, but this way it may be better if installed inside a virtual machine (Virtual Box, for example)
I have to evaluate ISE 13.1, do you think i'd better update to ISE 14 ?
How big is it when installed ? It may be i can install it for linux,
removing old stuff i should have 20Gbyte free in the ext3 partition
The next month it may be i will buy a bigger internal hard drive, something like 500Gbyte instead of the actual 120Gbyte
of which Windows XP has the 50%, the other 50% is for linux, and .. 60Gb today are not enough for such a stuff.
