Author Topic: GPIB IEEE 488 - Pic Library  (Read 3021 times)
Offline Clint
« on: August 16, 2013, 02:21:41 pm »
Afternoon all, anyone know of a PIC Based Library for the HP GPIB / IEE488 bus ?
g33K5 L1k3 80085
Offline Skimask
Re: GPIB IEEE 488 - Pic Library
« Reply #1 on: August 16, 2013, 11:28:59 pm »
Which PIC?
Which language?
Which which which?
Which Google did you use?
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline Clint
« Reply #2 on: August 17, 2013, 06:55:48 am »
Ill take a library from any pic for now.
I have both C and BASIC...
Is Which a place ? do they speak English in Which ?
I used the Google I own shares in and I refuse to use any other google on that basis.
Regards
Clint
g33K5 L1k3 80085
alm
  • Guest
« Reply #3 on: August 17, 2013, 01:03:12 pm »
What Skimask means is that a quick Google search gives at least four relevant hits on the first page. If you did a careful evaluation on each of these and determined that none of them meets your detailed requirements, then it would be good to share this and said requirements so people don't waste their time trying to help you. Otherwise I just gave you four options.
