which exploits the ability of the port's PINx register to toggle any pins you write a '1' bit to
One of the problems using this xor/toggle method on this avr is you will have to come up with a different method when it comes time to deal with the DDR register, and as already mentioned it gets cumbersome as soon as you have different ports involved and/or the test bits require some work to get into their respective bit positions.
Another thing you (Lomax) seem to hint at, is affecting the state of peripheral controlled pins (assuming the in/out instructions used in a rd/mod/wr sequence)- I'm not sure there is any mcu in which a peripheral has 'taken over' a pin for its own use where you can then 'override' its output on your own. In other words, if another pin on the same port is doing hardware pwm, your rd/mod/wr sequence will not affect it even though that pwm pin changed inside that sequence. You are preserving that pins 'non-peripheral' output state in any case (for example if you specifically wanted/set the pwm pin high when the pwm peripheral is not enabled, that state still gets preserved).
I treat all pins individually. If they belong to some group, I still treat them as individual pins. If I have a char lcd using 4 data pins, it will mean I can use any pins (due to availability, or for easy board routing) and easily change later as needed without any code changes except to specify which pin is wanted. It makes no difference they are not all set in the same clock cycle, and will be plenty fast for about anything that does not use a full port (at which point you will switch to dealing with a full port, or have a hardware peripheral that does the job).
For your avr, where the port/pin is known at compile time, the simple thing to do is treat these pins individually to get the sbi/cbi instructions produced. Done. I knew that when I posted the original example, but also knew this thread would go through various phases before most likely getting back to the original solution (pin manipulation is a popular subject, as no mcu user is excluded from its use). Sometimes you just end up back where you started when seeking a 'better' solution.
Here is a C++ way to deal with pins on your avr (in a limited way, just as an example)-
https://godbolt.org/z/Th8eqe7h7and that type of thing is mostly good as you contain/hide the details where they belong (not in your app code), plus have a single interface to your port peripheral that can be used in any project. BUT, when you have 8 lines of code that already does what you want, in a language you are already familiar with, in an app that does not see a lot of pin setup/manipulation, then those 8 lines of code are not so bad after all.
This avr is not that pleasant to work with compared with newer mcu's. The pin thing is one of them, dealing with constants in flash is another. Move up to an avr0/1 (or any 32bit mcu) and you get much nicer use of pins due to the set/clr/tgl registers, and the flash is mapped to data space so const use is as easy as it gets (const's get stored in flash and the storage/usage of them requires no extra effort on your part). A fractional baud rate generator is also nice in these newer avr's, along with an rtc, and... so on. Move up when you can.
