Are there any ICs which will control more than just 2 MOSFETs? 4 channel (1 IC per H-bridge) would be nice.
Yes, you can find 3 phase designs, with 6 mosfets or 6 drivers, but you need to check those to see if 2 can drive 3 full bridges.
Voltage and current looks ok, but the data sheet says nothing regarding pulse current? In general, what will be the limiting factor, the current itself or the thermal issues resulting from the high current?
Well, I would like an IC with higher current, but options seem quite limited. However, there is again the question regarding what is limitting the current.
Is it the current itself or the thermal issues that come along?
Basically A single pulse shall have the energy of approx. a 1000 uF capacitor (25V). Duty cycle will be <<1%. Important: the H-Bridges don't need to be activated simultaneously.
What does that mean, exactly ? It is a strange way to spec a bridge current load.
Normally you have running current and stall currents, and those are long-duration effects, as far as silicon goes. One stall a day may be << 1%, but bonding wires and die warm up in microseconds.
It is more common for MOSFET circuits to be
thermally designed, the peaks they can manage these days are often way above real circuit values.
There is a strong incentive to avoid heatsinks, so SMD packages and RDS values are chosen to make the thermal loading tolerable on a PCB.
If you really are dumping
"the energy of approx. a 1000 uF capacitor (25V)" in some sort of impulse circuit, you need to worry about the under voltage trips as what is the end-voltage of your pulse dump ?
What is the
actual load you are driving here, with what waveforms, and what are its specs ?
