Wondering of anyone had a solution for Programming The Renesas M38039FFFP In Circuit Without a Segger Flasher 5
I do not have the QFP64 adapter or I would just remove the chip and use the Xeltek 6100N.
The unit (Hakko FM-202) has a Serial Programming Header On the PCB.
I know Hakko will flash the latest firmware for free (I have Already Had 2 Done) but there has to be a faster way then 2-3 week turn.
Datasheet
https://datasheetspdf.com/pdf-file/1150500/Renesas/M38039FFFP/1Hakko FM-202 CN8 Programming Header Pinout:
Header Pin = M38039FFFP Pin
Pin 1 = Pin 12 P47/Srdy1 / (Busy)
Pin 2 = Pin 18 CNVSS (VPP)
Pin 3 = Pin 57/24 VCC/VSS
Pin 4 = Pin 13 P46/sclk1 (SCLK)
Pin 5 = Pin 15 P44/RxD1 (SDA)
Pin 6 = Pin 49 P37Srdy3/RD (OE) or (CS)
Pin 7 = Pin 19 RESET
Pin 8 = Pin 59 P30/DA1/AVSS
