Doesn't have ECC.
More directed at OP, rather than you.
You need to get your priorities right. There are many things, much more important than ECC.
Backups (reliable and decent).
Raid (or other ways of having multiple copies of the data, in the machine).
Decent, high quality/reliable storage medium (disks/SSDs).
UPS (as needed).
Reliable/decent/quality motherboards and cpus.
Reliable/tested software, which unfortunately can need paying for quality and vendor help/support.
By the time you have got and paid for all the above, you would probably already have ECC built in as standard, to the server. But it may well cost a small fortune. Also, it probably will use considerably more than the 1 watt max power consumption, the OP seems to be talking about.
tl;dr
It is very easy to come up with, what you can think are quite reasonable specifications.
E.g. A $10,000 car. I'm only paying $1,000 for a new one.
Fuel consumption 50 MPG, sorry, I insist on at least 2,000 miles per gallon.
ECC memory, all car systems must have that built in, with $0 extra budget to pay for it.
Car manufacturer wants 7 years to develop new car, I insist on it only taking a few days.
tl;dr2
Currently, ECC usually costs significant amounts of money, to have quality server hardware, which properly includes it.
Sadly, such is life.
tl;dr3
ECC is NOT magical.
Software quality/reliability, backups, UPS, cpu quality, SSD data integrity, etc etc. Are also (if not more), important, as well.
