Author Topic: HC32L110 complete erase  (Read 3968 times)
Offline buttimTopic starter
« on: August 28, 2023, 05:34:30 pm »
Anyone can tell me if this MCU can be completely erased in case the debug interface and/or the reset pin have been disabled?
I can't find any such information in the (translated) datasheet but some (https://github.com/pyocd/pyOCD/issues/1364#issuecomment-1098492831) say it should be possible.
Thanks
Offline IOsetting
  • Country: cn
Re: HC32L110 complete erase
« Reply #1 on: August 30, 2023, 02:47:05 am »
Translated from Datasheet Rev2.5 Page13
Programming mode
Support two programming protocols: ISP protocol and SWD protocol.
ISP protocol programming interfaces: P35, P36 or P27, P31.
SWD protocol programming interfaces: P27, P31.
When the chip receives the ISP programming instruction within a few milliseconds after the reset, the chip works in ISP programming mode and can be programmed. Use programmer device to program FLASH.
If the chip does not receive the ISP programming instruction within a few milliseconds after the reset is completed, the chip works in user mode and executes program code in FLASH.
Note:
It is suggested to reserve P35 and P36 as ISP programming interfaces;
For using P27 and P31 as ISP programming interfaces, please refer to PCN: PCN20200304-1 _ HC32L110HC32F003HC32F005 to improve the burning speed.
Datasheet and HDSC ISP tool can be downloaded from their product page
https://www.hdsc.com.cn/Category82
For HC32L110 https://www.hdsc.com.cn/Category82-1389
ISP programming uses UART port so USB2TTL dongle is required.
Offline DavidAlfa
« Reply #2 on: August 30, 2023, 03:25:13 am »
I guess you found that mcu somewhere in a device and you're trying to repurpose it?
Because for what it costs you can get a much better STM32G030F6P6 for same price or lower.
« Last Edit: August 30, 2023, 03:29:08 am by DavidAlfa »
« Reply #3 on: August 30, 2023, 12:43:09 pm »
Exactly. The device (https://www.ebyte.com/en/product-view-news.html?id=129) has an interesting radio module on it, the AX5243. That's the source of my interest
« Reply #4 on: August 30, 2023, 12:46:58 pm »
Programming mode
Note:
I'm not proficient in chinese so I can't read the datasheet from the link you specified. Instead I found an (automatically translated) english version. I noticed it talks of an ISP methos but I guess it must be supported by the current firmware. Or is it a built-in feature of the MCU? What software should I use to upload a different firmware using ISP?
« Last Edit: August 30, 2023, 01:12:03 pm by buttim »
Offline DavidAlfa
« Reply #5 on: August 30, 2023, 01:42:03 pm »
Probably it's the same as most, setting pin BOOT0=1 and powering it up.
« Reply #6 on: August 30, 2023, 03:29:32 pm »
Can't find any reference to such a thing in the datasheet
Online abyrvalg
« Reply #7 on: August 30, 2023, 05:47:47 pm »
From that translated fragment it looks more like some BootROM activated at each reset unconditionally (not requiring any pin pulled), waiting for some specific byte from the ISP tool within a short time window, then jumping to flash.
« Reply #8 on: August 30, 2023, 07:09:49 pm »
True. What worries me is that the reset pin can be multiplexed to a GPIO.
What would happen in that case? I'm asking because I actually found an ISP programming tool but I'm not having any success with it...
Offline IOsetting
  • Country: cn
« Reply #9 on: August 31, 2023, 03:00:59 am »
You don't actually need the RESET pin. Power it off -> on will do it. ISP tool and HcUnlock tool can be downloaded from the link I posted. (I attached the screenshot of the download page)
It's not recommended to re-program the module, unless you have the source code, otherwise you will easily brick it. HC32L110 is M0/M0+ based but the SDK is quite different from those of standard SPL/HAL/LL.
E-Byte uses HC32 chips quite a lot in their products. They mainly use STM8L before, but about 2 or 3 years ago, they switched to HC32. I got to know HC32 series only because I bought their test-kit of nRF24L01 module.
« Reply #10 on: August 31, 2023, 10:40:10 am »
Thanks a lot. I downloaded the unblock tool but when I launch it, it presents me a window like this, no idea what I should do
Offline IOsetting
  • Country: cn
« Reply #11 on: August 31, 2023, 11:56:51 am »
There is a PDF in the zip file, these are the content of this PDF translated by machine
HC32F003/HC32F005/HC32L110 unlocking instructions
1. Some users locked the SWD port of MCU due to improper operation when using MCU, resulting in MCU. Can't be used again. Now, an unlocking tool is provided to erase the program in MCU and save this kind of MCU.
2. The hardware needed for this operation is: USB to TTL serial port module; The required software is HcUnlock.
3. Operating steps
Step1, plug the USB to serial module into the USB interface of the computer.
Step2. Adjust the serial number of the serial port to COM4 according to the following figure. If the serial port has "delayed timing" option, then adjust its value to 1.
Step3: Connect the corresponding pins of the serial module with the corresponding pins of the MCU to be unlocked.
MCU.VCC <--- > serial module. VCC
MCU.GND <--- > serial module. GND
Mcu.txd (p31/p35) <-> serial module. RXD
Mcu. rxd (p27/p36) <-> serial module. TXD
MCU.RST(P00) <----> serial module. RTS/DTR
Step4, double-click to execute hcunlock _ 003 _ 005 _ 110.exe.
4. Remarks
At present, the serial port modules that have been tested and can be unlocked correctly are FT232 and CH340
It seems this unlock tool works only on fixed port COM4. The port number can be changed in Windows Device Manager (there are screenshots in the PDF).
For the RESET part, if the RESET pin is not available, you can connect TX, RX and GND only, then run this tool and quickly connect the VCC. HC32L110 is 5V compatible but I would suggest to try 3.3V first.
« Reply #12 on: August 31, 2023, 12:38:15 pm »
I renamed the port to COM4 and rebooted. Absolutely nothing happens when I launch the unlocker. The LEDs on the FT232 module never turn on so apparantly it is not trying to access the serial. I tried to access the port with a different program (Putty) at the same time and it works, so the com port is actually not in use it seems
« Last Edit: August 31, 2023, 01:02:15 pm by buttim »
Offline IOsetting
  • Country: cn
« Reply #13 on: September 01, 2023, 12:49:38 am »
I'll see if I can do a test in the weekend.
The following users thanked this post: buttim
Offline IOsetting
  • Country: cn
« Reply #14 on: September 02, 2023, 04:08:30 pm »
Confirmed: the unlock tool doesn't work.
I use a CH340 dongle and change the port to COM4, run the tool, nothing happens. It seems it didn't recognize the port, just kept reminding me to change the port to COM4.
Offline IOsetting
  • Country: cn
« Reply #15 on: September 02, 2023, 05:04:16 pm »
The good news is the ISP tool works.
The HC32L110 board I am using
Wiring:
* RTS  -> P00
* RX   -> P31
* TX   -> P27
* GND  -> GND
* 3.3V -> VCC
1. Switch the language to English.
2. Target MCU: HC32L110x4xx
3. Com Baud: 115200 (691200 always fails on my CH340)
4. Hex File: you need provide some dummy hex file, it's required but you can choose to erase without uploading
5. COM Setting: the port used by USB2TTL
6. Check Erase + Blank Check, leave Program,Verify,Encrypt unchecked. If you just want to test the communication without erase, uncheck them all.
7. Click Execute
Then it will reset the chip, do the erase and blank check. The output log tells the result of each step, 成功 means success.
The tests without connecting RTS to P00
1. Using reset button
If I click Execute and press RESET at the same time, at a 20% success rate it successfully connected to the board and did the erase.
2. Disconnect/Connect VCC manually
I tried to reconnect VCC and click Execute button at the same time, I tried many times with no luck. In theory there is a possibility but the time window may be too short.
« Last Edit: September 09, 2023, 02:29:59 pm by IOsetting »
Offline IOsetting
  • Country: cn
« Reply #16 on: September 02, 2023, 05:29:02 pm »
This can be achieved by circuit. I once made an auto-download circuit for STC8x 8-bit chips
Using this dongle I can erase HC32L110 without connecting RESET pin
« Reply #17 on: September 02, 2023, 10:35:46 pm »
Wiring:
* RTS  -> P00
* RX   -> P31
* TX   -> P27
* GND  -> GND
* 3.3V -> VCC
7. Click Execute
Then it will reset the chip, connect to it and do the erase and blank check. The output log is in Chinese, it tells the result of each step, 成功 means success.
The test of programming it without connecting RTS to P00:
1. Use reset button
click Execute and press RESET at the same time, a 20% success rate it successfully connected to the chip and did the erase.
I tried to reconnect VCC and click Execute button at the same time, but unfortunately I tried many times without any success. In theory there is a possibility but the time window is too short.
Many many thanks for the very detailed explanation. Tomorrow I will read all that again and see if I can solve my problem.
Just remember to reboot after you change name to a COM port otherwise the change will not have any effect.
