Author Topic: HDL & custom logic magic  (Read 3307 times)
Offline DajgoroTopic starter
  • Country: hr
    • hackaday.io
« on: April 20, 2014, 01:50:49 pm »
Hi.
A while ago, as a university project I designed(through schematic, not HDL) a CMOS random generator (the chip never got made) and I built a poc prototype out of 4000 series logic, and it worked. So later I wanted to get that same circuit working in a CPLD, but there is a problem. In order for the circuit to work it needs a specific combination of logic gates that really don't make any sense to the optimization algorithm that is used when synthesizing the logic, so it would always turn into a mess and I was never able to get the circuit working like that.
Is there a way to synthesize the logic in the exact way as described so that I can generate the messy logic that perform the entropy magic?
I am using Xilinx ISE.
P.S. I couldn't think for a better name for the topic  ???
Offline free_electron
    • SiliconValleyGarage
Re: HDL & custom logic magic
« Reply #1 on: April 20, 2014, 02:17:56 pm »
In quartus (altera) there is a flag to tell the synthesizer to create the logic as it is given. This flag only affects schematic entry. I use this to uygate skew generators made with chains of inverters and a tree-multiplexer that has equal length pathways.
You can do it also in verilog in quartus by writing the block as a netlist and telling the synthesiser not to touch manual netlists.
You can go even further by then hand placing and routing the critical section.
As for xilinx .. I don't know. Don't use em. Hate ISE.
Offline edavid
« Reply #2 on: April 20, 2014, 03:35:05 pm »
What is the operating principle?  Are you relying on relative gate delays or something like that?
  • Country: hr
    • hackaday.io
« Reply #3 on: April 20, 2014, 06:22:07 pm »
It is a design of mine, but the basic principle is that I have a bunch of oscillators built from xor gates and trimmed chains of inverters.
Hate ISE.
Why?
Online nctnico
« Reply #4 on: April 20, 2014, 10:18:38 pm »
You should be ably to use the basic building blocks of the FPGA (LUTs and flipflops). OTOH it would be much better to create a proper HDL version. Look for constraints to have control over timing.
Offline edavid
« Reply #5 on: April 20, 2014, 11:37:33 pm »
How do you avoid injection locking?
Offline Harvs
« Reply #6 on: April 21, 2014, 02:38:10 am »
One of the Xilinx VHDL demo code for the Spartan 3 was a ring oscillator built using inverters.  This was one of those things where you specify the logic and tell the optimiser not to touch it.
Might be worth searching for that code and having a look how they did it.
  • Country: hr
    • hackaday.io
« Reply #7 on: April 21, 2014, 03:01:16 am »
The oscillators are daisy chained, each phase shifting the next one, and as a result you get a really unstable oscillator.
Here is the project page:
http://projects.hackaday.com/project/384-CMOS-random-generator
Offline maxslug
    • Nikon Hacker
« Reply #8 on: May 08, 2014, 04:58:43 am »
You can hand-instantiate LUTs if you want to hand-craft the design.
OR you can use the dont_touch synthesis directive :
From http://www.xilinx.com/support/documentation/sw_manuals/xilinx2012_3/ug901-vivado-synthesis.pdf
(* dont_touch = "true" *) wire sig1;
assign sig1 = in1 & in2;
assign out1 = sig1 & in2;
You may need to dont-touch the LUTs too.
-m
Chip Designer and Janitor of https://nikonhacker.com
