Author Topic: ESP8266 + Arduino IDE 1.6.4 Portable - Full Install step-by-step Guide  (Read 2773 times)
Offline TJ232Topic starter
  • www.esp8266-projects.org
    • ESP8266 Projects
  As been asked so many times these days about, if anybody want to experiment with and needs some guidance,
please find below a step-by-step Install Guide for a Arduino 1.6.4 Portable environment. It's including also ESP8266 packages, ready for programming your ESP Boards.
INSTALL GUIDE:
FIRST RUN - Blinky time :)
Detailed step-by-step guide with pictures: ESP8266 + Arduino IDE 1.6.4 Portable - Full Install step-by-step Guide
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
Offline ralphd
    • Nerd Ralph
Nice little guide.
Does this work now without having to copy libiconv?
Unthinking respect for authority is the greatest enemy of truth. Einstein
    • ESP8266 Projects
Nice little guide.
Thank you.
If you follow the install guide above, for 1.6.4 no extra files needed.
