Author Topic: Help connecting SPI Flash memory to PSoC5 (hardware + firmware)  (Read 861 times)
Offline AlinikTopic starter
Hello everyone,
I'm working on a project using a PSoC5 (CY8C5888LTI-LP097) and I need to add an external SPI flash memory to store configuration data and logs. I don’t have much experience with external flash memories, so I’d appreciate advice on both hardware and firmware aspects.
Memory Selection
  • Which SPI flash memories (preferably Cypress or Infineon) are compatible with the PSoC5 and easy to integrate?
    I'm looking for a device with a capacity between 4 MB and 16 MB.
  • Should I opt for a Quad-SPI flash or is a standard SPI flash sufficient for a beginner?
    I'm trying to balance performance with ease of integration.
Hardware Considerations
  • Interfacing: How should I connect the SPI pins (SCK, MOSI, MISO, CS) of the PSoC5 to the flash memory? Do I need to use pull-up or pull-down resistors on these lines?
  • Voltage Levels: The PSoC5 operates at 3.3V. If the flash memory also operates at 3.3V, do I need any level shifting?
  • PCB Layout: Are there any schematic examples or best practices for PCB layout (trace length, decoupling strategies, etc.) that you would recommend for this interface?
Firmware Considerations
  • SPI Master Configuration: How do I configure the SPI Master in PSoC Creator to communicate effectively with the flash memory?
  • Libraries and Drivers: Are there any pre-existing Cypress libraries available for handling read/write operations with SPI flash memory?
  • Common Pitfalls: What common errors should I avoid during initialization and operation?
Extra Questions
  • Would you recommend Cypress flash memories like the S25FL116K or any other model in the S25FL series?
  • Are there any tutorials or reference designs specifically for interfacing a PSoC5 with SPI flash memory?
Any advice, documentation, or reference designs would be greatly appreciated!
Thank you in advance for your help.
