Author Topic: Help identify IC  (Read 16497 times)
Offline TheSteve
  • Living the Dream
Re: Help identify IC
« Reply #25 on: January 13, 2016, 06:06:36 am »
Pulled out two CCM's and the cable I used to interface with them. They are MKIV so they aren't quite the same. These are 1C0959799C. I only had to apply power and ground on the larger of the two connectors. I also recall that I had to connect via the k-line within 30 seconds of powering up or the module went to sleep. I could also use a programmed remote to wake up the module and then connect to it. As long as you're connected it will stay awake.
I have no idea how close/similar the wiring would be. On the MKIV module the wiring harness colors are orange for ground, positive is red with a black tracer and the K-line is grey with a white tracer.
VE7FM
Offline neonhomerTopic starter
« Reply #26 on: January 13, 2016, 03:10:47 pm »
Mine is a 1J0 959 799 AJ, with a blue harness plugs and a tan harness plug.
I will have to try to get it all hooked up, and then try communication as soon as I get it up and running.
One of the reasons I posted here on EEV (besides identifying the IC) was so I could figure out what died on this thing, and then either be able to repair it, or prevent it from happening again.
NeonHomer
"No Matter Where You Go, There You Are"
« Reply #27 on: January 15, 2016, 03:11:16 am »
Okay.. this is interesting... I have three of these now... Two junkyard ones, and the original one.
I can't talk to all three of them. I did some poking around on the board, and found the CANBus chip. There is power (9v) to it. I have 12vdc on various points on the board.  I still only have around .7vdc to the processor. This thing is almost acting like it is not fully powered up.
Bad thing is, I can identify almost every pin on one harness, but the other one, I can only find two wires... the service manual doesn't show the rest.
NeonHomer
