Author Topic: 404: ATTINY not found  (Read 919 times)
Offline ppTRNTopic starter
« on: December 11, 2022, 10:08:13 am »
Hi, I am currently working on a very simple progect in which I need to use a uC. Since it has to be used as a controller for a GPS module and a CAN transreceiver I chose an ATTINY841, which has 2 uarts, or an ATTINY84, with a single uart, so SoftwareSerial will be needed. Well, it is the first time that the semiconductor crisys hits me. These uCs arent available anywhere, and the few i found were sold at something like 13$ each, a clearly unacceptable price. How do you guys deal whit this situation while designing a new circuit? Do you start by what is available? But again, stoks changes very rapidly, so what is available today won't be tomorrow and vice versa. Please let me know what you think.
ps: more reasons why I choose ATTINY84(1): just as many GPIO pins I need, not much memory required (even ATTINY44(1) would be fine), analog comparator with bandgap reference. By the way, do you think it is ok to use the analog comparator as a voltage level controller of a battery? Since it has no hysteresis, when the battery level (properly attenuated) is very close to the reference, won't I just get a noisy output? If this is the case, how do you usually deal with it? Just using the ADC?
Thank you very much.
« Last Edit: December 11, 2022, 10:10:10 am by ppTRN »
Offline westfw
Re: 404: ATTINY not found
« Reply #1 on: December 11, 2022, 10:38:55 am »
How about an avr16dd20 or similar.   New, 2 UARTs, more memory, and in stock at several distributors, and cheap.
The following users thanked this post: 1001
Offline Psi
« Reply #2 on: December 11, 2022, 10:58:20 am »
ATMega162 also has 2x UARTS
Offline Psi
« Reply #3 on: December 11, 2022, 11:02:00 am »
I chose an ATTINY841, Well, it is the first time that the semiconductor crisys hits me. These uCs arent available anywhere,
err...
The following users thanked this post: ppTRN
« Reply #4 on: December 11, 2022, 11:25:59 am »
err...
Well this is akward. I even found them on farnell. Thank you all for the suggestions.
