Author Topic: Customized Pi Pico board  (Read 6398 times)
Offline profdc9Topic starter
« on: February 24, 2024, 03:38:24 am »
I designed my own Pi Pico board that has a nearly compatible pinout (except for 3V3EN) to the official Pi Pico PCB, but has customizations I wanted to make such as a different USB connector, bigger flash (16 MB), linear regulator, and easier resetting (no pulling the usb plug) for development.  I also did it to have an example of a Pi Pico project, and to have it be manufacturable at JLCPCB.  You can find it at:
https://www.github.com/profdc9/PicoAlt
Offline dobsonr741
Re: Customized Pi Pico board
« Reply #1 on: February 24, 2024, 05:48:01 am »
The schematics is off on GitHub
« Reply #2 on: February 24, 2024, 04:06:31 pm »
Sorry, the correct schematic is now there.   :P
Offline MarkT
« Reply #3 on: February 25, 2024, 02:37:28 pm »
Looks interesting - the linear reg and reset button are both useful I think.
I worry there's no copper area for the linear regulator to dissipate heat though - this is a 2-layer board I think, no hidden heatsinking internal planes?
« Reply #4 on: February 26, 2024, 03:25:12 am »
I made almost the entire back side solid copper.  See the attached picture.
« Last Edit: February 26, 2024, 03:27:40 am by profdc9 »
