Author Topic: how to indent VHDL and VERILOG sources ? (looking for an app/tool)  (Read 5228 times)
Offline legacyTopic starter
hi guys
i need to "indent" a lot of VHDL and VERILOG code,
just in order to make it look prettier
are there any tools to do that ?
i can use both Windows/Linux
Online nctnico
Re: how to indent VHDL and VERILOG sources ? (looking for an app/tool)
« Reply #1 on: May 04, 2014, 07:10:04 pm »
There are code beautyfier tools which apply a certain formatting to a source file. Google 'code beautyfier'.
« Reply #2 on: May 04, 2014, 07:14:06 pm »
i found C/C++ beautifier, are you sure there is a VHDL/VERILOG ones, too ?
if so, any suggestion about the specific one i'd better use ?
Offline jahonen
« Reply #3 on: May 04, 2014, 07:49:57 pm »
Emacs VHDL mode has a beautifier at least for VHDL.
Regards,
Janne
« Reply #4 on: May 04, 2014, 08:20:02 pm »
umm, if it is possible i'd prefer something i can use in script (bash or windows), i have a tone of .vhd files to be beautified
Offline FrankBuss
    • Frank Buss
« Reply #5 on: May 04, 2014, 08:25:05 pm »
I'm sure for the experts it would be just 3 lines of Emacs Lisp code :)
« Reply #6 on: May 04, 2014, 08:46:34 pm »
i do not know anything about lisp and emacs but .. i can learn it  :-+
Offline zapta
« Reply #7 on: May 05, 2014, 01:15:37 am »
Some ide's and editors can operate on entire directory trees, try eclipse, sublime, textpad, etc.
Sent from my Nexus 5 using Tapatalk
Offline scientist
  • User banned.
« Reply #8 on: May 06, 2014, 06:33:54 pm »
The Mojo IDE automatically formats VHDL, http://embeddedmicro.com/tutorials/mojo/mojo-ide although it's only in alpha.
Offline maxslug
    • Nikon Hacker
« Reply #9 on: May 08, 2014, 04:29:36 am »
If you're prettying it up just to browse you might consider using http://www.burbleland.com/v2html/v2html.html to make your life easier.
-m
Chip Designer and Janitor of https://nikonhacker.com
