Author Topic: Help please: PIC12F675 Beginner  (Read 11560 times)
Offline igendelTopic starter
  • Country: il
    • It's Every Bit For Itself (Programming & MCU blog)
« on: May 02, 2014, 02:16:00 pm »
Hello good people!
I'm trying to wrap my head around this humble PIC MCU, but there are so many variants and variations on the web  :o
Some background: I started learning about MCUs about 2 years ago, with Arduino, then moved on to "independent" AVRs using Atmel Studio, and some forays into MSP430G2. Now I got hold of a PICkit 1 (hey, don't laugh!  ;) ) and a couple of cheap PIC12F675s that are supported by it, so I installed MPLAB X w/ XC8, tried to write a Blink program and... nothing.
The process of burning the generated "production" HEX file using the PICkit 1 and its old, dedicated software seems to be working just fine, but I get no response from the MCU itself no matter what code I try. The old programmer isn't recognized by the IDE so I can't debug that way, and I'm still not willing to spend $$ on a modern programmer just for a little experimenting.
Obviously, I searched the web and these forums, but so far I only found code for other PICs, or for other compilers, or other IDEs... so, can someone please provide a working Blink code for my setup, with the correct register initializations? It doesn't even have to be commented, I can take it from there.
Thank you very much in advance!
Maker projects, tutorials etc. on my Youtube channel: https://www.youtube.com/user/idogendel/
Offline ElektroQuark
    • ElektroQuark
Re: Help please: PIC12F675 Beginner
« Reply #1 on: May 02, 2014, 02:25:15 pm »
Try MPLAB instead.
  • Country: il
« Reply #2 on: May 02, 2014, 02:42:57 pm »
Try MPLAB instead.
What good reason is there to use less-than-the-latest? If I can make this work, I won't stay forever with just the 675 and the old programmer, so I want to start as up to date as possible.
    • ElektroQuark
« Reply #3 on: May 02, 2014, 02:45:35 pm »
"The old programmer isn't recognized by the IDE so I can't debug"
Maybe with MPLAB you can try finding the problem.
Offline Sebastian
  • Country: py
    • Custom Tek
« Reply #4 on: May 02, 2014, 02:48:18 pm »
Could you post your code so we can see if that is the problem?
I would not switch back to the old MPLAB, I think X has a much better UI and it works great for me.
  • Country: il
« Reply #5 on: May 02, 2014, 02:54:43 pm »
I see - still, assuming the chip itself is ok, starting from a working code will be faster and more efficient than trying to debug a dubious code I don't even understand yet...  :)
I tried and mixed many versions, it's all a big mess. I'd rather have a clean start. Like, should I use the GPIO register or, say,  RA0? include pic12f675.h or something else?
Offline AlfBaz
« Reply #6 on: May 02, 2014, 02:56:30 pm »
Pickit 1 is not the only casualty, I believe the original ICD isn't supported either, at least for the pic32's
Offline Sebastian
  • Country: py
    • Custom Tek
« Reply #7 on: May 02, 2014, 03:06:10 pm »
I never used pic 12fs only 16f, 18f, and 24f so I don't know if there is anything different.
But in general with XC8 you have to include only xc.h because it automatically includes the standard libraries for the device.
I don't know if your device has an ADC but if it does you have to deactivate it because it is on at reset. (ANSEL = 0x00; or something like that). There could be other stuff you have to deactivate as well, so have a look at the datasheet. Then you have to set the 3-state bit of the pin you are using to 0 and you should be good to go.
Online mariush
« Reply #8 on: May 02, 2014, 04:00:56 pm »
pic12f675 is supported by XC8 v1.31 (you have the header files in  xc8\v1.31\include, but it's enough to just say #include <xc.h>  at the start of your main.c file and in "Project properties" in MPLAB X you have to select the chip you have so that the compiler will know what pic chip to use)
However, MPLAB X may not be able to "communicate" with Pickit 1, you should try  the old MPLAB. You can download it from here:
http://www.microchip.com/pagehandler/en-us/devtools/dev-tools-parts.html
(Scroll down to MPLAB IDE archives, and you have somewhere on the right side all the way down MPLAB 8.92).
XC8 may not work right with MPLAB, or MPLAB may not recognize it as a compiler, in which case you can download from the same page Hi-Tech C compiler (scroll down more and you have there a ftp link).
Hi-Tech C compiler is basically previous versions of XC8, Microchip bought Hi-Tech and just renamed it to XC8, so all you have to do is install hi-tech c, select it as compiler in MPLAB and then instead of  #include <xc.h>  you say #include <htc.h>  , that's all there is to it. Everything else should work the same.
Once you get everything working (mplab + hi-tech c/xc8 + pickit 1)  you should write a simple program, that simply blink a led.  Set internal oscillator, set it to default 4 mhz, disable analog input (ansel*) on that port, set the port to output (it should be by default output) then set that pin to 1 so that you can connect a led between that pin and ground and get it to light up.  make sure you have a loop at the end to keep it running, otherwise i'm not sure if the compiler will add the loop code by itself.
Offline dannyf
« Reply #9 on: May 02, 2014, 04:08:04 pm »
Two tricks for most PICs:
1) set the fuse in the code;
2)  turn off any ancillary functions (like analog and comparators).
If you still cannot get it work after this, I can write you one.
Offline Sebastian
  • Country: py
    • Custom Tek
« Reply #10 on: May 02, 2014, 05:23:11 pm »
Oh, I forgot the configuration bits. Go to Window -> PIC memory view -> Configuration bits. Now a windows should open below where the code is. Set the configuration bits how you need them and click on generate. Copy the generated code into a new header file called config.h and include it in main. Now you are good to go.
  • Country: il
« Reply #11 on: May 02, 2014, 05:38:52 pm »
... hours later ...
I somehow got something to work. The code is this:
#include <xc.h>
// Generated by the Configuration Bits wizard:
#pragma config FOSC = INTRCIO   // Oscillator Selection bits (INTOSC oscillator: I/O function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-Up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON       // GP3/MCLR pin function select (GP3/MCLR pin function is MCLR)
#pragma config BOREN = OFF      // Brown-out Detect Enable bit (BOD disabled)
#pragma config CP = OFF         // Code Protection bit (Program Memory code protection is disabled)
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
int main(int argc, char** argv) {
    ANSEL = 0;
    TRISIO = 0;
    GPIO = 0;
    while (1) {
        GPIO = 0;
        _delay(100000);
        GPIO = 1;
        _delay(100000);
    return (0); // I know I don't need this, it was simply in the template
It blinks at ~4 times  a second.
When I wrote "GPIO = 1 - GPIO" it didn't work (was constantly on). Why?
Edit: using an auxiliary variable for state, the "1 - state" does work:
    while (1) {
        s = 1 - s; // s is unsigned char
        GPIO = s;
        _delay(1000000);
« Last Edit: May 02, 2014, 05:49:06 pm by igendel »
Offline Sebastian
  • Country: py
    • Custom Tek
« Reply #12 on: May 02, 2014, 05:48:24 pm »
What do you want to archive with "GPIO = 1 - GPIO"?
Do you want to toggle one pin? GPIO is 8 bit wide and I think you only want to control one pin right? Use GPIObits.GPx where x is the number of the pin between 0 and 7, if your package actually features 8 I/O pins. To toggle GP0 use "GPIObits.GP0 = ~GPIObits.GP0"
  • Country: il
« Reply #13 on: May 02, 2014, 05:50:58 pm »
Yes, I'm familiar with how such ports work and how to access them in a real application... I simply wanted something to blink for now, I don't care about the other pins.
Still, why didn't it work?
Online Andy Watson
« Reply #14 on: May 02, 2014, 06:23:48 pm »
What blinking thing have you connected, and more importantly how have you connected it?
  • Country: il
« Reply #15 on: May 02, 2014, 06:40:59 pm »
A regular 5mm red LED, anode through a 330 Ohm resistor to pin, cathode to GND.
It blinks happily now, the problem is, I think, how the compiler treats that statement.
Online Andy Watson
« Reply #16 on: May 02, 2014, 06:47:43 pm »
I was considering the possibility that you had loaded the port down too much - a port read will always return the state of the pin, not the latch. But 330 into an LED should not be a problem. It does look like a compiler quirk! It would be interesting to pull out the assembly code and see what the compiler has done with the GPIO=1-GPIO;
Offline dannyf
« Reply #17 on: May 02, 2014, 07:22:38 pm »
Look beyond that statement.
I outlined the solution for you earlier.
  • Country: il
« Reply #18 on: May 02, 2014, 10:15:45 pm »
Sorry, I don't follow you on this one.  What did I miss?
Online Andy Watson
« Reply #19 on: May 02, 2014, 10:28:42 pm »
Can you extract the assembly code? I don't have access to a C compiler for the PIC and I am intrigued to know why that statement didn't work.
  • Country: il
« Reply #20 on: May 02, 2014, 10:55:13 pm »
Good question... where can I find it? I'm not too familiar with the toolchain, so far I can only see the raw HEX "program memory".
Online mariush
« Reply #21 on: May 02, 2014, 11:11:05 pm »
In MPLAB X , from menu .. Window > Output > Dissasembly Listing File
or window > pic memory views > program memory, then select code in the combo box.. but the above option is nicer
  • Country: il
« Reply #22 on: May 02, 2014, 11:26:10 pm »
Wow, that IS convenient!  :)
Here's what I get for the mysterious code line:
22:                    GPIO = 1 - GPIO;
03EA  1283     BCF STATUS, 0x5
03EB  0305     DECF GPIO, W
03EC  3AFF     XORLW 0xFF
03ED  3E01     ADDLW 0x1
03EE  0085     MOVWF GPIO
And here's for the working alternative:
20:                    s = 1 - s;
03E6  1283     BCF STATUS, 0x5
03E7  0323     DECF s, W
03E8  3AFF     XORLW 0xFF
03E9  3E01     ADDLW 0x1
03EA  00A0     MOVWF __pcstackBANK0
03EB  0820     MOVF __pcstackBANK0, W
03EC  00A3     MOVWF s
21:                    GPIO = s;
03ED  0823     MOVF s, W
  • Country: il
« Reply #23 on: May 02, 2014, 11:39:43 pm »
Ohhhhh.... I added these two initializations:
    CMCON = 7;
    ADCON0 = 0;
And it DOES blink with "GPIO = 1 - GPIO". However, I still have no idea why it works. Explanations or datasheet references are welcome...
Online Andy Watson
« Reply #24 on: May 03, 2014, 12:11:56 am »
    CMCON = 7;
    ADCON0 = 0;
Ah! Must have misunderstood the sequence of events as posted (DOH!) Putting the ADCON=0, disables the ADC inputs. The default, from reset, is to have the ADC inputs enabled. When the inputs are enabled as ADC inputs they read, digitally, as zero.
http://ww1.microchip.com/downloads/en/DeviceDoc/41190G.pdf
page 21 onwards.
« Last Edit: May 03, 2014, 12:17:26 am by Andy Watson »
