Author Topic: I.MX 8M Plus coprocessor flash/boot problem (remoteproc)  (Read 702 times)
Offline teleportboyTopic starter
  • Country: kg
« on: December 11, 2023, 11:30:46 am »
I'm trying to flash a Cortex-M7 coprocessor, but I'm encountering problems.
My steps:
1) Copy fw.elf to /lib/firmware/
2) Specify the firmware file name: echo fw.elf > /sys/class/remoteproc/remoteproc0/firmware
3) Start the flashing process: echo start > /sys/class/remoteproc/remoteproc0/state
However, at step 3, there's an issue where the system immediately freezes after writing start to state, and to recover it, I have to reboot the machine.
Offline krho
  • Country: si
Re: I.MX 8M Plus coprocessor flash/boot problem (remoteproc)
« Reply #1 on: December 12, 2023, 11:32:03 am »
I'm not using it. But I'd be surprised if you could directly upload the elf file. I suggest that you read the fine print regarding this.
