Author Topic: help to read MCU firmware  (Read 2083 times)
Offline nassihTopic starter
  • Country: ma
« on: July 05, 2023, 07:58:57 pm »
hello I need your support, if someone can explain to me how can I read the content of the microcontroller (TMS320F28021) and write it on several MCUs of the same family without going through Code composer,I 'have: programmer XDS100 ,motherboard with a JTAG interface and UNIFLASH software from Texas instrument.
I plugged the XDS100 programmer into the JTAG interface then I opened UNIFLASH software I go to read target memory the process went well, but when I want to export the firmware I can't figure out all these thing also the file is only a few kilo octet, if someone can explain the step by step or if there is a software that is easier than this,please i nedd help
Offline justjason
Re: help to read MCU firmware
« Reply #1 on: September 10, 2023, 07:35:09 pm »
Do you have some pictures of the board and connectors ?
Offline KG7AMV
  • Rhine_Labs
    • My Personal Blog
« Reply #2 on: September 23, 2023, 01:04:43 am »
That chip family has a Flash and a One Time Programmable Area.
I have not used the programmer you have. I have programmed that family of MCU's only with my universal programmer with and adapter for specific package.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #3 on: September 23, 2023, 02:30:22 am »
To export memory contents to a file, check section 7.4.5 of the CCS User's Guide.
https://software-dl.ti.com/ccs/esd/documents/users_guide/index.html
