Author Topic: help to resolve DS1307  (Read 570 times)
Offline alizare368
« on: July 20, 2019, 02:09:17 pm »
Hi everyone
I want to launch a DS1307 with stm32f0 ,and I used this code's , but it doesn't work.
Someone know what the problem it??
I2C_HandleTypeDef hi2c1;
DMA_HandleTypeDef hdma_i2c1_rx;
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_I2C1_Init(void);
static uint8_t ds_rbuf[8];
char txt_buf[10];
int main(void)
MX_GPIO_Init();
  MX_DMA_Init();
  MX_I2C1_Init();
  /* USER CODE BEGIN 2 */
uint8_t ds_tbuf[8]={0};
HAL_I2C_Master_Transmit(&hi2c1,0xd0,ds_tbuf,8,100);
lcd_initilize();
HAL_I2C_Master_Receive_DMA(&hi2c1,0xd1,ds_rbuf,8);
  /* USER CODE END 2 */
while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
lcd_gotoxy(0,0);
sprintf(txt_buf,"%02d",ds_rbuf[0]);
lcd_puts(txt_buf);
/* USER CODE BEGIN 4 */
 void HAL_I2C_MasterRxCpltCallback(I2C_HandleTypeDef *hi2c)
  /* Prevent unused argument(s) compilation warning */
  UNUSED(hi2c);
  /* NOTE : This function should not be modified, when the callback is needed,
            the HAL_I2C_MasterRxCpltCallback could be implemented in the user file
/* USER CODE END 4 */
Offline SiliconWizard
Re: help to resolve DS1307
« Reply #1 on: July 20, 2019, 04:34:51 pm »
Hmm. If you're going to launch it, how is it ever going to come back?
 ;D
Offline alizare368
« Reply #2 on: July 21, 2019, 02:13:16 pm »
I don't understand. :-[
Online TK
« Reply #3 on: July 21, 2019, 02:17:12 pm »
DS1307 is a 5V device, STM32 is 3.3V.  How are you interfacing both ICs?  Do you have the required pull-up resistors on the i2c lines?
Offline alizare368
« Reply #4 on: July 21, 2019, 02:29:33 pm »
I pull-up the  SDA and SCL line with a 10K resistor to 3.3v.
Online TK
« Reply #5 on: July 21, 2019, 02:32:01 pm »
You need to use 5V on the DS1307 and add level shifting logic between the 2 ICs... low voltage side pulled up to 3.3V (STM32), high voltage side pulled to 5V (DS1307)
Offline alizare368
« Reply #6 on: July 21, 2019, 02:37:52 pm »
I connected VCC to 5v.
« Reply #7 on: July 21, 2019, 02:42:00 pm »
Yes, jokes aside, this is a 5V device. So first make sure you power it with a 5V supply.
Since it's I2C and since the DS1307's datasheet states a min voltage of 2.2V for the "1" input level, it may not need an additional level shifter. Just pulling up SDA and SCL to 3.3V should reasonably work I guess?
Now there is also the software side. Make sure you initialized the I2C peripheral correctly. Have you looked at SCL and SDA with a scope? Is there any activity to be seen on this I2C bus?
Also, your code looks fishy regarding the use of DMA.
You're issuing a "HAL_I2C_Master_Receive_DMA(&hi2c1,0xd1,ds_rbuf,8);", and then issuing the same again in the HAL_I2C_MasterRxCpltCallback() function, which doesn't seem to make sense as it is.
First try with blocking calls only. If everything is well, you can always move on to use DMA.
« Reply #8 on: July 21, 2019, 02:44:07 pm »
Which VCC? Supply the DS1307 with a 5V supply, yes. But do not supply the MCU with a 5V supply, you will fry it.
