One other thing, some context for my original question since maybe someone has an entirely different and better idea on how to power this little project board I'm making.
I am using the ESP32 to read a vacuum pressure sensor. It will run off two 18650's in series, which give 7.4V nominal but the battery output could go from ~6V min. discharged to 8.4V max charged. The sensor requires 9-28VDC power. The sensor outputs RS232 so I'm using a MAX3232 RS232-to-TTL converter, which requires 3.3V, to get the serial data to the ESP RX/TX pins.
I currently have one tiny dc-dc convert to give 12VDC to the sensor (I wanted to give it something above it's bare minimum 9V since I thought that might help minimize any effect of waning battery voltage) and one dc-dc converter to give me 3.3V for the MAX. I was hoping I could get away with just two dc-dc converters by powering the ESP32 on its 3.3V output (or maybe giving 3.3.V to its 5V input?), the subject of this post.
Ideally I'd like some kind of tiny buck-boost board that takes 6-8.4VDC input and has three outputs; 3.3V, 5V and 12V (12 or whatever in that 9-28V range). I didn't find any although I did find this board which takes 7-30VDC in (I just realized that 7V is higher than I'd like and won't let me discharge the batteries too much) and give 5 & 3.3V out:
https://www.aliexpress.com/item/1005007501353930.htmlI ordered a couple in case it turns out the 3.3V into the ESP32 doesn't work.
Does anybody know of a little buck-boost board that can run off of two 18650's in series and has 3.3, 5 and ~12V outputs?
A totally different question, which I don't want to sidetrack the 3.3V discussion, but would designing a board like that be hard? I'm no electronics expert but when I look at those little switching dc-dc converter boards they only have a dozen or so components.
