Logic analyzer shows
1. Start bit
2. Slave address ending with 0 (if 7 bit address, MSBs are the address, LSB is the R/W bit, which is zero for write)
And then..
3. ??
ACK or NACK? If NACK, that's as far as you will get. Double check the address is correct and the circuit is ok.
If you got an ACK, circuit is ok. Software/peripheral problem. Does this module trigger ISR? Did you set up your ISR?
exactly as found in the quick start guide
I hope you at least modified the slave address... What are you communicating with? It is up to the slave to ACK after the address has been sent. You can't "dry run" it without an actual working slave.
