Author Topic: HLVD interrupts 4 times per event on pic18f27J53  (Read 703 times)
Offline spinnakerTopic starter
« on: March 22, 2019, 11:39:12 pm »
I have a pic18f27J53 which has HLVD.   I have everything working the way I want  except that each event interrupts 4 times.    That doesn't seem right.   I have been able to code around it but just does not seem like I should have to.
Has anyone use HLVD?
#include <xc.h>
#define LOW_POWER_SETPOINT 0b1001
#define NORMAL_POWER_SETPOINT 0b1010
#define _XTAL_FREQ 8000000
unsigned interruptCount = 0;
#define DETECT_LOW_POWER 0
#define DETECT_NORMAL_POWER 1
unsigned char  detectPowerMode = 0;
unsigned char enterSleep = 0;
void main(void)
   OSCCONbits.IRCF0 = 1;
   OSCCONbits.IRCF1 = 1;
   OSCCONbits.IRCF2 = 1;
   TRISAbits.TRISA0 = 0;
   TRISAbits.TRISA1 = 0;
   LATAbits.LATA0 = 1;
   OSCCONbits.IDLEN = 0;
    HLVDCONbits.HLVDEN = 0;                 // Disable HLDV
    HLVDCONbits.HLVDL = LOW_POWER_SETPOINT;             // Set point to low value
    HLVDCONbits.VDIRMAG = detectPowerMode;     // Interrupt when voltage drops
    PIR2bits.HLVDIF = 0;                    // Clear the HLVD interrupt flag
    HLVDCONbits.HLVDEN = 1;                 // Enable HLDV
    RCONbits.IPEN = 1;
    INTCONbits.GIEH = 1;                    // Enable general interrupts high
    PIE2bits.HLVDIE = 1;                    // Enable low voltage detect interrupt
   while(1)
       LATAbits.LATA1 = 0;
       __delay_ms(100);
       LATAbits.LATA1 = 1;
       __delay_ms(100);
       if (enterSleep)
           Sleep();
    return;
__interrupt(high_priority) void interrupts_highPriority(void)
    if (PIR2bits.HLVDIF == 1)
        interruptCount++;
        if (interruptCount<4)
            return;
       interruptCount=0;
        if (detectPowerMode == 1)
            LATAbits.LATA0 = 1;
            detectPowerMode = DETECT_LOW_POWER;
            enterSleep=0;
        else
            LATAbits.LATA0 = 0;
            detectPowerMode = DETECT_NORMAL_POWER;
            HLVDCONbits.HLVDL = NORMAL_POWER_SETPOINT;
            enterSleep =1;
« Last Edit: March 23, 2019, 12:08:49 am by spinnaker »
