Hi all.
First off, just thinking aloud here.
Just some thoughts on how I'd implement a low power consumption (and low cost)
remote solar powered station with a long-range 433Mhz transceiver.
There may be many ways to do this, and I thought it might be fun to get some ideas from you all.
OK, first we have some 'standard' components, and some unknown options.
The MCU (client) will need to send back a 'heartbeat' signal via wireless every 5 minutes.
If the remote station is in 'operational' mode it will need to send back info every 1 minute to the 'host'.
The remote unit may be switched back to 'heartbeat' mode by the controlling (host) station at any time.
1. To keep things simple, the MCU will be an Arduino board. There are other boards out there which may be better at power consumption, but for now we'll settle on a 'standard' - I don't use Arduino's BTW,
but do know people who use these (at a higher - maybe not so much smarter level)...
2. Scrap the onboard regulator circuit as it uses too much power (even in sleep mode).
2b. Create a low power (LDO) regulator circuit for the Arduino board at 5vDC.
2c. Use an existing power management IC (more info to be obtained on this yet).
3. The solar panel will need a charge controller for a battery. Let's say a 12v 10w panel or now,
and a 12v 12aH SLA battery.
4. If the solar panel can't sufficiently charge the battery (ie. drops below 11 volts), then the unit needs to shut down completely via a latching relay (maybe a blinking LED to indicate though).
5. The MCU goes into sleep mode for maybe 10 seconds, then checks status.
Now, we have possibly 2 relays (or FETs) used in this.
6a. Relay #1 controls the power to the whole unit. This would probably be a latching type relay so that once power is removed from the circuit only manual recharging and user intervention would be involved.
6b. Relay (or FET) #2 powers the transceiver only when required.
So, most of my ideas involve power management.
Only one question I can think of initially..
Is there a 'monolithic' chip which would handle MOST of this, or is it better to DIY?
Any other ideas are much appreciated, and as I mentioned, this is just me thinking aloud..
