Hello everybody,
The EEVblog community has made the padauk programmer which I have and used it. I also have the 5S-I-S02B padauk provided emulator. For testing my programs I use this emulator using the IDE provided by padauk itself which supports mini c language.
My question is, can I convert this mini-c programmed code to the ihex file supported by the freepdk programmer? If not I have to first check the code in emulator, then write the same code for sdcc compiler which does not feel good to me.
The IC that I am working with is PMS171B which is OTP type and I can not reprogrammed it to fix any minor mistake for which I have to use emulator.
