Author Topic: How do we know if software has way too many EEPROM writes?  (Read 13351 times)
Offline TomS_
Re: How do we know if software has way too many EEPROM writes?
« Reply #75 on: February 13, 2018, 02:14:37 pm »
Easiest way to get thanks on the EEVblog forum .. respond to a treez thread.
Seriously, what is with that? Even posts that seem to criticise and poke fun get thanks!!? :wtf:
The following users thanked this post: ocset
Offline 3db
« Reply #76 on: February 14, 2018, 10:48:43 am »
:TomS_
Even your one.   :-DD
The following users thanked this post: TomS_, ocset
Offline bson
« Reply #77 on: February 14, 2018, 11:01:01 pm »
To answer the original question, if you have a hardware debugger and can access the chip with it, you can disassemble enough to find the EEPROM writing code and set a hw breakpoint there.  Configure the breakpoint to automatically resume and use it to count the number of times that code is executed.  If fusing prevents access, see if you can find a copy of the binary/hex/elf file that gets programmed and program it yourself to a blank device using the debugger, then find the EEPROM write code and count using a breakpoint.  If it needs to run on the actual board just reflow your own unfused and accessible one onto it.
