Author Topic: How do you program an ATtiny10 with PICkit 4?  (Read 512 times)
Offline DigitalDeath
« on: June 11, 2021, 03:03:03 am »
Since they use a different protocol called TPI (Tiny Programming Interface)  that uses a single wire for both input and output?
I know about the USBasp programming but they tend to fail when the MIOSI pin is connected to other devices.
Is there some settings os something I need to do to make it work?
I'm new to this series and I mostly do STM32 so I'm not familiar with where the resources are.
Thanks
John.
Offline ComradeXavier
Re: How do you program an ATtiny10 with PICkit 4?
« Reply #1 on: June 11, 2021, 01:13:05 pm »
Start with Microchip's PICkit 4 product page. There you will find links to documentation, including a user's guide and a quick start guide.
« Reply #2 on: June 11, 2021, 01:28:16 pm »
This is not a regular AVR processor. It uses a different protocol for programming because it has a bidirectional pin instead of miso and mosi
« Reply #3 on: June 11, 2021, 01:49:59 pm »
The resources you need are on Microchip's website. The quick start guide I linked has only two pages. On page 2 is a table of how to connect a PICkit 4 to devices with a variety of programming interfaces, including TPI (as used on the ATtiny10).
You may also need to refer to the ATtiny10 product page and datasheet. Section 1 (Pin Configuration) and Section 15 (Programming Interface) will contain any details specific to the TPI interface on the ATtiny10.
The following users thanked this post: DigitalDeath
« Reply #4 on: June 11, 2021, 11:10:55 pm »
This is an answer thank you :-+.
The first one sounded like "read the manual"  :-DD
Offline MarkR42
« Reply #5 on: June 15, 2021, 11:06:01 am »
I am just pleased that someone else is using the Attiny10. I use the usbasp arduino-based programmer and it works well. There is a lot you can do with 32 bytes of ram and 1/2k flash :)
