Electronics => Microcontrollers => Topic started by: legacy on September 13, 2014, 02:32:06 pm
hi guys
i have been studying this (http://www.fpga4fun.com/JTAG2.html) tutorial that shows a few details about the jtag tap.
(http://www.fpga4fun.com/images/JTAG_TAP.gif)
I have understood
- how to determine the IR register length
- how to read the IDcode (manufacture, revision, etc etc)
- hot to determine how many devices are in the jtag chain
i can't understand how to read a DR register without corrupting it!
the jtag tap seems to read/write at the same time, so if you go into Caputure-DR you make the TAP machine to copy a pointed (1) register content into "scan register", so you can read it with Shift-DR through TDI, but … every time you issue a Shift-DR you also write into scan register content, so when you go into Update-DR you are copying the register content back to the pointed register content
and here we go, getting a corruption :wtf:
do i miss something in the TAP behavior ? who can clarify with an example ?
thanks
(1) you can point registers with IR instructions, for example if IR is equal to b1110 then you are pointing the IDCode register (read only)
That depends on an instruction you are issuing. Some instructions like IDCODE ignores Update-DR, some have a paired instruction to read data for future updates (SAMPLE can be used to get some default value for future INTEST/EXTEST). Or in the most general case you can shift in the same values you are shifting out: in Shift-DR state you see the first bit value on TDO before shifting in something on TDI - so just set TDI=TDO and clock out the next bit.
imagine you have an Advance Debug Interface (aka ADI) connected to your jtag TAP machine, how could you ran the desk with its registers ?
does the tap need a pair of instructions (read, write) for each the ADI's registers ?
each read instruction will ignore the write-back phase in the update-Dr state
each write instruction will take the write-back phase in the update-Dr state
is it correct ?
example
the ADI unit has 4 registers {ADI.r0, ADI.r1, ADI.r2, ADI.r3}
does the jtag TAP machine need to have these custom instructions {{rd_ADI.r0, wr_ADI.r0}, {rd_ADI.r1, wr_ADI.r1}, {rd_ADI.r2, wr_ADI.r2}, rd_ADI.r3, wr_ADI.r3}} ?
Why not? It should work.
But there are other ways also: for example, ARM debug unit (ICEBreaker) registers are accessed with a single IR instruction, but DR has address, r/w, data fields
