Author Topic: Anyone Use the MAX32625 ARM Dev Board with MBED OS?  (Read 3751 times)
Offline TomKattTopic starter
  • Electro-BOOMER
« on: September 09, 2026, 11:59:05 am »
So recently I picked up a MAX5715 SPI 12bit 4 Channel DAC dev board from Digikey and despite the description of DAC board only I got the full kit with a mating MAX32625MBED ARM M4 controller dev board.  Not a bad score for $24 ;-)
Anywho, not wanting to let a free ARM board go to waste I started following the instructions for the HelloWorld example DAC code, but rather than pointing to an online compiler as suggested I get redirected to a Github entry.
Just curious if anyone here has played with the MAX32625 boards or used the online MBED compiler so I can check out how it works...  I see there are some old links in the Wayback Machine, but haven't been able to get things fully sorted out.
The DAC board can be used with any ucontroller, and that's why I got it.  It would be nice if I got the ARM board figured out, but if not no big deal and it will go in the rainy day box for future experiments.
TIA
EDIT - Apparently, the whole mbed os thing has been sunsetted and is no longer available.  We live in a world where new products come out and within 6-7 years they are no longer supported - and worse, manufacturers decide to erase critical files rather than archive them somewhere.
BUT - it turns out these boards are supported by the Arduino IDE and uploading is as easy as copying the compiled bin file to a virtual usb drive that appears when you plug the board into a pc.  Though the Ardunio 'programmer' script similarly relies upon a depreciated Windows utility, so I just need to copy manually rather than letting a bat script do the work.
So it will be used for something ;-)
PS - I noticed that Digikey shows qty 1 left in stock...  If this stuff is up your alley, you might consider checking it out as somehow they are selling the $80 kit for the $24 DAC eval board only price...  And the bare DAC ic chip alone sells for $15, so it's a $10 premium to have it mounted on a nice breakout board that I'd need anyway.
2896344-0
« Last Edit: September 10, 2026, 06:19:13 pm by TomKatt »
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Offline mike449
Re: Anyone Use the MAX32625 ARM Dev Board with MBED OS?
« Reply #1 on: September 20, 2026, 05:37:04 pm »
The SDK for MAX32625 is also deprecated, so there is no officially supported way to develop for it. Too bad, it is a nice M4F micro with interesting peripherals.
Claude Code was able to find the older SDK version from ADI website for me, but it was a few months ago, it may be completely gone now. Arduino libraries look limited.
Offline dobsonr741
« Reply #2 on: September 20, 2026, 07:12:06 pm »
Nice. What DigiKey part number got you both boards?
