EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
ESP32: Do I follow copper keep-out rule even with elevated module?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: ESP32: Do I follow copper keep-out rule even with elevated module? (Read 3840 times)
james_virtudazo
Newbie
Country:
on:
September 16, 2026, 08:38:35 am »
I'm making a PCB design around an ESP32 module which will attached with female pin headers. I've added a fill on the B.Cu layer for the GND plane so it goes underneath the antenna as well. Realizing this I thought I should remove some of the copper directly below it. What are your thoughts? I haven't designed that many PCB's yet. This is also my first time posting on this forum.
Last Edit: September 16, 2026, 08:40:48 am by james_virtudazo
Logged
Doctorandus_P
Super Contributor
Country:
Re: ESP32: Do I follow copper keep-out rule even with elevated module?
Reply #1 on:
September 16, 2026, 08:49:00 am »
My first thought is Yes, keep metal away from the immediate area around the antenna. I guess that even the mounting screw in the corner will degrade the antenna performance (a little bit).
Logged
james_virtudazo
james_virtudazo
Newbie
Country:
Reply #2 on:
September 16, 2026, 09:00:40 am »
Thanks. I also thought of moving that mounting screw hole in the corner but didn't know where else to put it. Maybe I'll keep it there to test and remove if necessary.
Logged
voltsandjolts
Supporter
Country:
Reply #3 on:
September 16, 2026, 09:10:50 am »
Your vias look small. In general, don't use the manufacturer minimums, use generous sizing where possible and save the the minimums for where you really need them (i.e. a very tight board). Do you have rules setup? e.g.
https://gist.github.com/darkxst/f713268e5469645425eed40115fb8b49
Logged
james_virtudazo
james_virtudazo
Newbie
Country:
Reply #4 on:
September 16, 2026, 09:35:04 am »
Yeah. I realize that I referenced a setup from an STM32 board design tutorial. What is generally recommended? Also, the traces are 0.3mm for signal, 0.5mm for power (3.3V), I added a 1.0mm for 5V since I also have a MAX98357 module included.
Logged
james_virtudazo
Newbie
Country:
Reply #5 on:
September 16, 2026, 09:38:36 am »
I just looked at the file you shared. I'll look at it closely later.
Logged
Fire Doger
Frequent Contributor
Country:
Stefanos
Reply #6 on:
September 23, 2026, 12:46:34 am »
This image might help you better understand why this keepout exists.
This is somewhat how the 3D field looks like of this antenna.
If you add metal parts it will disturb this field.
And this picture is not very good, it's not exactly a donut, if you take a closer look they recommend to place it to the corner, but different corner based on if the antenna looks left or right.
You can take a closer look at this appnote but it's harder to imagine in 3d space
https://www.ti.com/lit/an/swra117d/swra117d.pdf
Last Edit: September 23, 2026, 12:50:18 am by Fire Doger
Logged
james_virtudazo
james_virtudazo
Newbie
Country:
Reply #7 on:
September 23, 2026, 01:35:52 am »
Thank you for this.
This was my 2nd time making a prototype. In the first one I had it on the other side. I'm not sure if I noticed anything about the connection but then again I wouldn't know what to look for.
This the placement I followed for the PCB.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
