Author Topic: how to check either Controller working or damaged  (Read 1663 times)
Offline ect_09Topic starter
« on: October 28, 2014, 11:13:29 am »
Hi,:(
i want to know that how to check that either Controller working or damaged ,
am confused because i have PIC 18f452 and its being detect automatically when i want to load HEX file it and at the end it shows message that programming finished successfully, (i attached the image).
but when i run this on hardware its PORT does not responding..no voltage on its output.
what should i do..????
code is here
#include<htc.h>
// PIC 18F452 fuse configuration:
// Config word 1 (Oscillator configuration)
// 40Mhz crystal input
__CONFIG(1, OSCSDIS & HSPLL);
// Config word 2
__CONFIG(2, BORDIS & PWRTDIS & WDTDIS);
// Config word 3
__CONFIG(3, CCP2RC1);
// Config word 4
__CONFIG(4,  LVPDIS & STVREN);
// Config word 5, 6 and 7 (protection configuration)
__CONFIG(5, UNPROTECT);
__CONFIG(6, WRTEN);
__CONFIG(7, TRU);
#define _XTAL_FREQ 40000000   //MHz
void delay_sec(unsigned char seconds)    // This function provides delay in terms of seconds
unsigned char i,j;
for(i=0;i<seconds;i++)
for(j=0;j<100;j++)
__delay_ms(10);
void main()
// Make RB0 zero
TRISB = 0;     // Make RB0 output
while(1)
PORTB = 0x55; // Make RB0 one
delay_sec(1);   // delay of one second
PORTB = 0xAA; // Make RB0 zero
Offline Pack34
Re: how to check either Controller working or damaged
« Reply #1 on: October 28, 2014, 03:35:45 pm »
Are you sure that your external oscillator is functioning properly?
Also I would suggest using the snipping tool, or pressing ALT+PRINT_SCREEN for screenshots. This will slim up your screenshots to the window that you're using.
http://windows.microsoft.com/en-us/windows/use-snipping-tool-capture-screen-shots#1TC=windows-8
Offline dannyf
« Reply #2 on: October 28, 2014, 03:43:35 pm »
You read the datasheet, write a good piece of code and compile and burn it to your chip. And observe.
in your case, your code us wrong.
jucole
  • Guest
« Reply #3 on: October 28, 2014, 04:24:26 pm »
You could try this neat little program called "PIC18 SIMULATOR IDE" http://www.oshonsoft.com/pic18.html  it's free to tryout; so you can load in your hex file and setup some LEDs to flash or LCD etc and see if your code works.
