Presumably instructions which output to pins are never optimised.
There are no instructions that output to the pins. GPIOs are memory mapped, and generally declared as volatile in the header file.
Tangential aside: Not quite the same thing, but the behavior of the MCU does (potentially) vary depending on the memory address targeted by an instruction according to the device's memory map, and this includes writing to a memory-mapped IO register versus RAM. The ARMv7-M architecture (Cortex-M3, -M4, and -M7) defines Normal, Device, and Strongly-Ordered memory types. Accesses to Normal memory are expected to not have side effects, so those accesses are not guaranteed to happen in the order or quantity or at the size that the program specifies. "Program" here does not refer to the C source code, but the actual machine instructions being executed by the processor, so this is entirely separate from any compiler considerations. Accesses to Device and Strongly-Ordered memory are assumed to have side effects and are therefore guaranteed to happen in program order, quantity, and size. In practice, the as-executed memory accesses are more likely to vary from program memory accesses in devices with cache, or more sophisticated devices like the M7, which is dual issue, superscalar, and has a longer pipeline with branch prediction, but the architecture documentation does not guarantee that the M3 or M4 will access memory in any particular way except as required by the memory attributes. Fortunately most of this is transparent to the programmer, as the memory map for a given device should place all of the registers and memories into parts of the default memory map with the appropriate types, with GPIO and other peripherals in the "Peripheral" block which is defined as "Device" memory, but in some cases you may still need to use memory barriers or MPU attributes to ensure correct behavior.
The relevant documentation for this is the ARMv7-M Architecture Reference Manual, section A3.5 for the curious/masochistic.
