I’m actually using an Adafruit Metro M4 running CircuitPython.I want to know where to get another board that can take a USB keyboard and communicate with my Metro over I2C, (I can’t attach a shield because I’m already using another shield for graphics)
I would suggest the very cheap CH554 or CH559 20-pin controllers with 8051 core
If you used C instead of CircuitPython, you could use tinyusb for the USB host side and would not need any additional hardware.
Quote from: SiliconWizard on January 18, 2023, 08:31:48 pmIf you used C instead of CircuitPython, you could use tinyusb for the USB host side and would not need any additional hardware.Or should he wait for IPL to be finished and all his problems will be solved p.s. The I stands for Imperium until it changes again of course.
