So after sorting out the other problem another one arises, this time during build it looks like the PC is expecting the Nano to respond but gets nothing in return.
The Nano is connected and is receiving data from the PC since the RX LED flashes every 5 secs, and the build would terminate immediatly after starting when the Nano is unplugged.
This here is what i see when attempting to build:
"C:\Program Files\Arduino\hardware\tools\avr\bin\avrdude.exe" -C "C:\Program Files\Arduino\hardware\tools\avr\etc\avrdude.conf" -c stk500v2 -b 115200 -p atmega328p -P COM6 -U flash:w:"C:\Documents and Settings\2029-pc\My Documents\teacup\Teacup_Firmware-master\teacup.hex":i
avrdude.exe: stk500v2_ReceiveMessage(): timeout
avrdude.exe: stk500v2_getsync(): timeout communicating with programmer
avrdude.exe: stk500v2_command(): failed miserably to execute command 0x10
avrdude.exe: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude.exe: stk500v2_command(): failed miserably to execute command 0x11
avrdude.exe: stk500v2_disable(): failed to leave programming mode
avrdude.exe done. Thank you.
RC = 1 - Build terminated
Upload terminated abnormally.
Can't figure this one out, but one line cought my eye:
this check.
So i can override this test and i guess it should upload but i don't know where to set the "-F" to do so.
This turned out to be much more hassle than anticipated and i need a little help.
Thanks.
Otherwise ArduinoIDE works fine so i'm not sure why it wouldn't work witht the Teacup Firmware.
