Author Topic: I2C on STM32F4 [SOLVED]  (Read 6615 times)
Offline DELTA67Topic starter
Re: I2C on STM32F4
« Reply #25 on: August 21, 2023, 10:23:30 pm »
Ok, I'll retry again.
Re: I2C on STM32F4
« Reply #26 on: August 22, 2023, 08:52:05 am »
I simulated that example with a 24c02 (Addr = 0xA0) and it partially worked.
How did you built it? It seems that it's based on the standard peripheral driver. The keil uvision 5 uses the CUBEMX HAL.
can you attach your project and all the files used in simulation please?
Offline DavidAlfa
Re: I2C on STM32F4
« Reply #27 on: August 22, 2023, 01:47:45 pm »
The link I posted earlier only uses CMSIS headers, no peripheral library of any kind, should work just fine.
Have you tried?
I'm using CubeIDE.
Re: I2C on STM32F4
« Reply #28 on: August 22, 2023, 04:35:29 pm »
I've found a working example for STM32F4 here:
https://blog.embeddedexpert.io/?p=613
I've made some modifications in order to get it working for the BLack PILL (F411):
* In main.c:
- I commented the clock config in order to use default 16MHz HSI clock
//SysClockConfig();
* In i2c.c:
- I enabled the pull-ups for PB8 and PB9
GPIOB->PUPDR|= 1<<16 | 1<<18;
- I modified the values of CR2, CCR and TRISE registers:
I2C1->CR2|= 16; // APB1 = 16MHz
I2C1->CCR|= 80;
I2C1->TRISE= 11;
Et voilĂ  !!
But when testing in PROTEUS it does not work as before. No start condition and no address transmission.
Later, I'll try with a lower frequency for APB1 (8MHz) and lower freq for SCL (50kHz) and see.
Thanks for ALL for your help
« Last Edit: August 22, 2023, 04:42:15 pm by DELTA67 »
Offline DavidAlfa
Re: I2C on STM32F4
« Reply #29 on: August 22, 2023, 04:41:47 pm »
The model is definitely bugged.
As in the datasheet, I2C SR2 MSL bit goes to 0 (Slave mode) when a stop is detected.
I have some code using that flag, it worked perfectly in real hardware.
MSL never goes back to 0 in Proteus.
Just use LL. Does exactly what you would do by hand. No overhead, no bloat. Just skip rewriting the wheel.
This is my function:
ErrorStatus I2C1_MasterTransmit(uint8_t DevAddress, uint8_t *pData, uint16_t Size)
  ErrorStatus status = SUCCESS;
  LL_I2C_GenerateStartCondition(I2C1);
  while(LL_I2C_IsActiveFlag_SB(I2C1) != 1);
  LL_I2C_TransmitData8(I2C1, DevAddress);
  while(!LL_I2C_IsActiveFlag_ADDR(I2C1) || !LL_I2C_IsActiveFlag_TXE(I2C1)){
    if(LL_I2C_IsActiveFlag_AF(I2C1))
      break;
  LL_I2C_ClearFlag_ADDR(I2C1);
  if(LL_I2C_IsActiveFlag_AF(I2C1)){
    status = ERROR;
    LL_I2C_ClearFlag_AF(I2C1);
  else{
    while(Size--)
      LL_I2C_TransmitData8(I2C1, *pData++);
      while(!LL_I2C_IsActiveFlag_TXE(I2C1));
        status = ERROR;
        break;
  while(!LL_I2C_IsActiveFlag_BTF(I2C1));
  LL_I2C_GenerateStopCondition(I2C1);
  while(LL_I2C_IsActiveFlag_MSL(I2C1));
  return status;
__STATIC_INLINE void LL_I2C_GenerateStartCondition(I2C_TypeDef *I2Cx)
  SET_BIT(I2Cx->CR1, I2C_CR1_START);
__STATIC_INLINE void LL_I2C_GenerateStopCondition(I2C_TypeDef *I2Cx)
  SET_BIT(I2Cx->CR1, I2C_CR1_STOP);
__STATIC_INLINE void LL_I2C_TransmitData8(I2C_TypeDef *I2Cx, uint8_t Data)
  MODIFY_REG(I2Cx->DR, I2C_DR_DR, Data);
__STATIC_INLINE uint32_t LL_I2C_IsActiveFlag_ADDR(I2C_TypeDef *I2Cx)
  return (READ_BIT(I2Cx->SR1, I2C_SR1_ADDR) == (I2C_SR1_ADDR));
And so on. That's LL. Inlining avoids any slow calls. Simple functions and calls, nothing convoluted.
« Last Edit: August 22, 2023, 04:50:25 pm by DavidAlfa »
Re: I2C on STM32F4
« Reply #30 on: August 22, 2023, 09:45:31 pm »
I confirm that.
I've tested with different APB1 frequencies (16, 8 and 4MHz) and SCL frequencies 100 and 50kHz.
Thanks David alpha, wek and Others.
How to tag this thread [SOLVED] ?
Offline DavidAlfa
Re: I2C on STM32F4
« Reply #31 on: August 22, 2023, 10:03:22 pm »
Edit the title in the first message?
Re: I2C on STM32F4
« Reply #32 on: August 23, 2023, 08:31:03 am »
Ok, thanks.
