Electronics => Microcontrollers => Topic started by: sdscotto on August 29, 2011, 06:41:16 pm
Title: ICD capable replacement for 16F627A
Post by: sdscotto on August 29, 2011, 06:41:16 pm
Does anyone have a recommendation for a pin compatible replacement (DIP18) for the 16F627A that includes ICD?
I have been unable to locate one using the parametric search on Microchip's page although I'd be surprised one doesn't exist.
Thanks in advance,
scotto
Title: Re: ICD capable replacement for 16F627A
Post by: oPossum on August 29, 2011, 09:33:26 pm
PIC16F87 and PIC16F88, or any 18 pin 18F series part.
Post by: BBQdChips on August 30, 2011, 02:53:40 am
PIC16F1826/PIC16F1827 come to mind.  I'm assuming you want a PDip?
I'm not positive they are pin compatible (completely).  VDD/VSS are centered on either side, but it strikes me there's something different about port A on the 627/8 layout.  Better check the datasheet on that.
Also, 16F818 and 819
You must not have looked at the MAPS on the site.
http://www.microchip.com/maps/microcontroller.aspx (http://www.microchip.com/maps/microcontroller.aspx)
It's a bit easier to use than the parametric, though, it lacks linking to the product pages... (dumb)
Post by: sdscotto on August 31, 2011, 03:26:53 am
16F87 is a possibility, 16F88 is not as all of PORTB is in use.   I hadn't considered moving up to the 18F as a drop in replacement.  Good idea, I'll check into that as an option.
Thanks.
Post by: sdscotto on August 31, 2011, 03:29:43 am
I had not used the MAPS.  I didn't even know it existed.  Thanks.
Digging through more datasheets....
