Author Topic: ICD3 inductor noise. Design flaw or feature? Maybe I'm just having bad luck?  (Read 10952 times)
Offline ArpTopic starter
    • Henriks bits n pieces
I think they're going to send me a second replacement. Maybe the replacement I got was an old returned unit with the same problem. If third ICD3 fails I'll see if I can manage to put a load on it. Lowering noise floor is more important than the warranty imho :D. Thanks for the advice
Btw, seems like I'm not the only one with this problem. After googling I found this from 2010 that sounds related:
http://www.microchip.com/forums/m476054.aspx
I received a second replacement today. It's an older revision with a green PCB instead of a red. Now when Power & Active is lit it's completely silent. Only when status it lit there is a slight squirm but nothing too depriving. Reckon Microchip got a bad second batch of components? :D
Offline AndyC_772
Resurrecting this old thread because I too now have an ICD3 that whistles. The noise comes and goes, it's not really consistent or predictable.
Anyone else got this problem? Is there a simple fix that doesn't involve sending it back to Microchip?
Offline Sal Ammoniac
I have two ICD3s (both have red PCBs) and neither of them makes any noise either connected to a target or just connected to a PC's USB port.
"That's not even wrong" -- Wolfgang Pauli
Offline heize0
  • Country: cn
Quite a long time post ago. I came into the same problem. It's quite noise. Replacing C18(below U26) with a solid-state electrical capacitor solved the problem at all and give you a quiet world.
