Author Topic: Identifying unknown microcontroller  (Read 1819 times)
Offline BottersnikeTopic starter
« on: June 23, 2023, 09:15:25 pm »
« Last Edit: March 19, 2024, 12:18:27 am by Bottersnike »
Offline brucehoult
Re: Identifying unknown microcontroller
« Reply #1 on: June 24, 2023, 12:58:32 am »
> The firmware is in Motorola SREC format, if that helps, though I don't recognise the machine code as anything I'm used to.
You have the FIRMWARE?  That should be the first thing you show us.
The following users thanked this post: amyk
Offline asis
  • Country: ru
« Reply #2 on: June 25, 2023, 01:18:27 am »
Maybe it's "BQ" - then it is related to battery power or charge monitoring.
This is from the BMS area and TI nomenclature.
Look at the diagram again from this angle.
Offline amyk
« Reply #3 on: June 25, 2023, 04:28:08 am »
This. Unless you're under some sort of NDA that prevents you from doing so, give us all the information you know and we'll be able to help more.
