Weird, I'm using find to look for that Makefile.incl and I can't find one.
Edited;
Well, apparently this is some third party Makefile, no? From that libopencm3 library?
Edited 1;
Ok, so as I am very unaware about how things works I started comparing some other FreeRTOS projects across github, and apparently, the workflow should be something like:
1 - Create my project, by simply creating a folder
2 - Clone FreeRTOS repository into this folder I just created
3 - Add libopencm3, if needed, as a submodule.
I hope this is correct so far. If not, please correct me.
After this, I think it's time to use libopencm3 library Makefiles and edit them according to my board and needs.
This is where things starts getting more tricky, I guess. So, I would need some help to be able to keep going.
