Author Topic: IMU Kalman Filter  (Read 926 times)
Offline AurentiacoTopic starter
  • Country: tr
IMU Kalman Filter
« on: February 19, 2024, 12:24:17 pm »
Hello
« Last Edit: February 20, 2024, 02:59:56 pm by Aurentiaco »
Offline m98
Re: IMU Kalman Filter
« Reply #1 on: February 19, 2024, 12:39:39 pm »
The library you are looking for: https://github.com/Reefwing-Software/Reefwing-AHRS
Nice overview over the different filters: https://www.olliw.eu/2013/imu-data-fusing/
  • Country: tr
« Reply #2 on: February 20, 2024, 01:39:07 pm »
Thank you for your reply. I looked at the github repo that you send but couldn't understand how can I implement it to my code could you give more information about if you know. Could you help me?
Offline m98
« Reply #3 on: February 20, 2024, 03:35:12 pm »
You deleted your initial post, so I'm not sure what you were trying to do, but just add the library to your project and modify one of the examples. This should have everything you need to get started: https://github.com/Reefwing-Software/Reefwing-AHRS/blob/main/examples/nano33BLErev2/nano33BLErev2.ino
Offline SiliconWizard
« Reply #4 on: February 20, 2024, 08:08:00 pm »
OK.
Offline peter-h
« Reply #5 on: February 20, 2024, 08:18:22 pm »
Inertial navigation has interesting applications in some parts of the world :)
« Reply #6 on: February 20, 2024, 08:30:13 pm »
Given that there's nothing in the post, and that chances are the OP will never reply, we don't know what they are after exactly, nor whether it's even worth posting.
But just as always, if the topic may be of interest to anyone else, know that this very topic is a huge, gigantic rabbit hole that you may spend years on. Good luck!
Online voltsandjolts
« Reply #7 on: February 20, 2024, 08:48:16 pm »
IIRC they were building a device for attachment to a golf club head and using imu to calculate head speed. Not something I would need, everyone can clearly see my swing is crap,  but somehow I make it to the 19th.
Offline peter-h
« Reply #8 on: February 21, 2024, 09:45:21 am »
If they want the speed at the ball impact point, just interrupt two IR beams. I did that to measure the pellet speed of an air rifle. Took maybe 10 mins to build.
Offline coppercone2
« Reply #9 on: February 22, 2024, 11:28:34 am »
