Author Topic: Infineon XMC4500 Relax Kit  (Read 2845 times)
Offline legacyTopic starter
« on: November 25, 2017, 02:23:46 pm »
Got a sample for 5 USD yesterday
I wonder: how good/bad is it?
and what about the support on software side?
it's written "supported by DAVE": a RAD? no thanks!
Rapid
Applications
Development
Alternative? (ok, I may write the BSP &C from scratch
using the datasheet, but ...  :D )
Re: Infineon XMC4500 Relax Kit
« Reply #1 on: November 25, 2017, 02:27:07 pm »
UM  :popcorn:
« Reply #2 on: November 25, 2017, 02:29:52 pm »
« Reply #3 on: November 26, 2017, 03:11:11 pm »
so, I downloaded the file "Infineon.XMC4000_DFP.2.9.1.pack"
that should contain a lot of examples and good code for the XMC4500 Relax Kit board
but ... I get strange errors when I try to import it into the PackageManager
I am on WindowsXP, and I can't switch to Windows7,8,10
It seems everything you can download, even in the 32bit support, is ... for Windows7 at least
so, how can I get examples and code, now?  :-//
damn  :palm: :palm: :palm:
« Reply #4 on: November 26, 2017, 04:16:53 pm »
 :wtf:
« Reply #5 on: November 26, 2017, 04:31:32 pm »
Packages can be downloaded from here  :-//
But I only see "Infineon.XMC4000_DFP.2.9.1.pack"
no more "infineon.XMC4000_DFP.2.8.0.pack"
(supposing it was compatible with XP-software)
« Reply #6 on: November 26, 2017, 04:36:39 pm »
I am with Keil MDK-ARM v5.14
« Reply #7 on: November 26, 2017, 04:41:59 pm »
Since V5.20 and later,  MDK-ARM  is incompatible to Windows XP!
ref here, but what about packages?
Online jaromir
  • Country: sk
« Reply #8 on: November 26, 2017, 05:52:11 pm »
I enjoyed my share of fun with Infineon ARMs - https://hackaday.io/project/27250-mcu-how-tos-reviews-rants/log/70767-infineon-scary-movie-part-one
After working with ARMs from ST, NXP, Freescale (now NXP), TI and Silabs, this one was somehow surprising to me.
« Reply #9 on: November 26, 2017, 07:42:55 pm »
I don't like DAVE
does someone happen to have MDK519.exe ?
can't find around, and it may solve the problem I have
« Reply #10 on: November 26, 2017, 10:19:15 pm »
Um, here examples for Eclipse.
Good!!!
Unfortunately there is no material for the built-in Ethernet.
« Reply #11 on: December 04, 2017, 01:27:23 pm »
So, I got Keil MDK v5.18 (the last one available for WindowsXP/32bit)
and I was able to import the Infineon's packages, including examples
unfortunately now the tool says that I need a special license among the following
MDK-PRO MDK Professional Edition
MDK-PRO-T MDK Professional 1 year term
MDK-PRO-FL MDK Professional Edition Floating
Currently I have a MDK-ARM-FL MDK Standard Edition Floating, and the compiler refuses to use the special blocks requested by Infineon's Packages  :palm: :palm: :palm: :palm:
In short: I can compile a "led blinking" example (since I can directly address a gpio easily), but I can't compiler examples that use Ethernet, SD, Cordic-Engine, etc, those parts are pre-compiled-binaries and require a special license  :palm: :palm: :palm: :palm:
The alternative sounds like writing everything from scratch, assembly, C, the whole BSP and drivers, which is of course possible but it's a very time consuming activity  :-//
