Author Topic: ESP8266 - ST7032i I2C LCD Display Driver  (Read 6197 times)
Offline TJ232Topic starter
  • www.esp8266-projects.org
    • ESP8266 Projects
« on: March 23, 2015, 11:27:53 am »
   If you need for your ESP Projects a LCD Display , might worth to take in consideration also a ST7032i one.
Good price and easy to use,  I2C compatible interface, so less data pins used.
For more details: http://www.esp8266-projects.com/2015/03/display-time-st7032i-i2c-lcd-display.html
Test Video :
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
Offline Laurynas
  • Country: lt
Re: ESP8266 - ST7032i I2C LCD Display Driver
« Reply #1 on: March 23, 2015, 01:25:28 pm »
Nice,
How much current does is need on idle?
can it go to sleep and how much does it consume in sleep mode?
I'm running esp8266 from 3x1.2V batteries (it can handle >4V nicely) and adding a battery friendly display sounds like a nice option to have.
    • ESP8266 Projects
« Reply #2 on: March 23, 2015, 01:53:43 pm »
Nice,
The used one is a good quality COG display, operating at around 0.18mA.
You can keep it shutdown until needed so consumption is virtually zero.
Backlight can kill your "run-for-months" dreams, at around 20-25 mA. Been a high res/sunlight friendly display you don't need backlight, so can stay off. If you want to use it in pitch black environments it's another story.
I will suggest you to use a 3V LDO regulator between you batteries and ESP module. Going over 3.4V can kill the beast inside.
Also you can easy replace you batteries with a Li-Ion rechargeable one: http://www.esp8266-projects.com/2015/03/mailbag-arrival-new-battery-solution.html
Offline neslekkim
  • Country: no
« Reply #3 on: March 24, 2015, 09:47:14 am »
In your blogposts, could you add links to where you source the various items?, i'm wondering about that display, and the charger-pcb.
Offline dannyf
« Reply #4 on: March 24, 2015, 10:29:18 am »
You have become the resident expert on anything esp8266, :).
Keep up the good work.
    • ESP8266 Projects
« Reply #5 on: March 24, 2015, 11:12:40 am »
If is OK for everybody I can do it, don't know exactly the rules here. It's ok for you all? Dave?
I was told that my account will be deleted from arduino forum by one of the local gods for only posting my articles about esp8266  :-//
    • ESP8266 Projects
« Reply #6 on: March 24, 2015, 11:18:51 am »
Thank you dannyf for your appreciation. It's nice to see your work rewarded.
I'm doing my best to bring you more nice and good related stuff soon. Also CBDB DevBoard Rev.2 it's on it's way to the world :)
