Author Topic: Intel Edison  (Read 34856 times)
Offline miguelvp
Re: Intel Edison
« Reply #50 on: September 12, 2014, 02:52:55 am »
At least their DDR3 operates at 400MHz I believe.
Offline timb
    • timb.us
Re: Intel Edison
« Reply #51 on: September 12, 2014, 10:40:23 am »
Damn, that really sucks... What the hell, Intel?
I guess I was just expecting it to have *some* means if high speed I/O. Lately my work with ARM chips has been on the higher end; I.e.,  TI's Sitara.
TI really got it right with PRU-ICSS cores in the AM335x series. It's basically two small, fully programmable MCUs, each with independent memory (plus a shared block) and full access to all the I/O on the system. They're programmable from the ARM side, so you can easily swap programs and I/O mapping as you need it!
There's a nice project where a guy turned a BeagleBone black into an 8 channel, 100+MHz logic analyzer via the PRUs. They basically read data in real time and use DMA transfers to stick it in memory, where the ARM core can process it when it gets time.
Sent from my Smartphone
Offline timb
    • timb.us
Intel Edison
« Reply #52 on: September 12, 2014, 12:05:11 pm »
Oh, I'm not building a LA, I just mentioned it as an example of the usefulness of having a realtime subsystem embedded with your CPU. (Be it an FPGA or PRUs.)
It's really a shame, on paper it looks like a nice chip; dual 50MHz cores, plus a 100MHz 486-class MCU, Bluetooth a and WiFi, all wrapped up in a tiny little POP chip.
It's sad there's no way to get data in or out of it to take advantage of it!
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
Re: Intel Edison
« Reply #53 on: September 12, 2014, 12:15:20 pm »
I just got a DE1-SoC dev kit from Terasic and it has a dual core 800MHz ARM Cortex-A9 w/1GB of RAM and an FPGA with 85k gates all in one neat little platform.  It's gonna be fun if I ever get any time to play around.
