Electronics => Microcontrollers => Topic started by: pulverizers on July 31, 2013, 02:00:52 pm
Title: Interfacing Nokia 1200 with microcontrollers
Post by: pulverizers on July 31, 2013, 02:00:52 pm
After a frantic search for info on using the nokia 1200 via f-bus, i've decided to post on the forum for help.
AFAIK, nokia 1200 uses f-bus protocol ver 3 which is not well documented on the web. What should I do to interface it with MCU to send SMS,calls etc?
Title: Re: Interfacing Nokia 1200 with microcontrollers
Post by: ivan747 on August 07, 2013, 02:22:17 am
Does it really have to be that phone? You could have it much more easy if you had a phone that could be fed standard AT commands via RS-232.
Post by: Psi on August 07, 2013, 02:27:38 am
Some cheap gps car trackers with cell chips can be hacked easily to accept AT commands.
Don't ask my for specific models though.
