Author Topic: Interrupt latency benchmarking on CH32V003 w/ and w/o hardware-stacking (HPE)  (Read 9695 times)
Online HwAoRrDkTopic starter
The WCH CH32V003 microcontroller with its QingKeV2 RISC-V CPU core has a slightly different interrupt controller (named Programmable Fast Interrupt Controller, or PFIC) than the higher-spec CH32V30x series with the QingKeV4 CPU core, specifically related to how the Hardware Prologue/Epilogue (HPE) feature works.
The HPE hardware stacking feature, when enabled, automatically saves a certain set of CPU registers upon an interrupt firing, and restores them again after the ISR returns. This way, code within the ISR does not have to perform this work, and thus enhancing performance by supposedly decreasing interrupt latency (i.e. how long between the event that triggers the interrupt, and the ISR being able to perform whatever actions in response).
On the CH32V30x, the HPE feature saves registers in a single cycle to a private internal hardware stack area which supports 3 levels of depth. However, on the CH32V003, HPE saves registers to the general stack area in RAM (and with a maximum depth of 2).
However, in a recent other thread, the discussion turned to whether, given that the CH32V003 just saves to in-RAM stack like normal, there is actually any performance advantage to interrupt latency.
So, I decided to benchmark it, following roughly the same testing methodology as newbrain in a thread about the CH32V307.
The code I wrote to perform the benchmark goes as follows:
- PC1 and PC2 are configured as outputs, and PC3 as an input.
- PC1 is connected externally to PC3.
- An EXTI interrupt is configured for PC3 with a rising-edge trigger.
- In the main loop, PC1 is set high.
- In the EXTI ISR, PC2 is set high.
- The ISR also makes a call to a sub-function, in order to create a worst-case scenario where all registers have to be saved.
Using an oscilloscope, I measured the period between the rising edges of the two output signals (PC1 in main loop to PC2 in ISR).
For the test case with HPE disabled, the ISR was marked with __attribute__((interrupt)). For the case with HPE enabled, the ISR uses __attribute__((interrupt("WCH-Interrupt-fast"))). The without-HPE case was compiled using mainline GCC 12.2 and -mabi=ilp32e -march=rv32ec_zicsr -mcmodel=medany -misa-spec=2.2 options. The with-HPE case was compiled using WCH's GCC 8.2 fork and -mabi=ilp32e -mcmodel=medany -march=rv32ecxw options. Both were also compiled with -Os.
The chip was initialised to run at the default 24 MHz using the HSI oscillator.
Here is the ISR disassembly for the case without HPE:
0000021a <EXTI7_0_IRQHandler>:
 21a: fd810113          addi sp,sp,-40
 21e: c23a                sw a4,4(sp)
 220: c03e                sw a5,0(sp)
 222: d206                sw ra,36(sp)
 224: d016                sw t0,32(sp)
 226: ce1a                sw t1,28(sp)
 228: cc1e                sw t2,24(sp)
 22a: ca2a                sw a0,20(sp)
 22c: c82e                sw a1,16(sp)
 22e: c632                sw a2,12(sp)
 230: c436                sw a3,8(sp)
 232: 400117b7          lui a5,0x40011
 236: 4711                li a4,4
 238: cb98                sw a4,16(a5)
 23a: 3f31                jal 156 <foo>
 23c: 400107b7          lui a5,0x40010
 240: 40078793          addi a5,a5,1024 # 40010400 <__global_pointer$+0x2000fc00>
 244: 577d                li a4,-1
 246: cbd8                sw a4,20(a5)
 248: 5092                lw ra,36(sp)
 24a: 5282                lw t0,32(sp)
 24c: 4372                lw t1,28(sp)
 24e: 43e2                lw t2,24(sp)
 250: 4552                lw a0,20(sp)
 252: 45c2                lw a1,16(sp)
 254: 4632                lw a2,12(sp)
 256: 46a2                lw a3,8(sp)
 258: 4712                lw a4,4(sp)
 25a: 4782                lw a5,0(sp)
 25c: 02810113          addi sp,sp,40
 260: 30200073          mret
And the ISR disassembly for the case with HPE:
 21a: 400117b7          lui a5,0x40011
 21e: 4711                li a4,4
 220: cb98                sw a4,16(a5)
 222: 3f15                jal 156 <foo>
 224: 400107b7          lui a5,0x40010
 228: 577d                li a4,-1
 22a: 40e7aa23          sw a4,1044(a5) # 40010414 <__global_pointer$+0x2000fc14>
 22e: 40078793          addi a5,a5,1024
 232: 30200073          mret
The results are as follows:
Without HPE: 1.45 us
With HPE: 0.87 us
So, using HPE results in an interrupt latency that is 0.58 us shorter!
The supposition was that because the CH32V003 simply does in hardware what software would be doing anyway, it would be little-to-no faster. But here we see that it is over half a microsecond faster. This must mean that there is definitely something special going on when it is saving to the stack with hardware.
« Last Edit: March 31, 2023, 06:38:25 am by HwAoRrDk »
The following users thanked this post: jklasdf, thm_w, rhodges
Offline brucehoult
With HPE: 0.87 us
So that's 14 clock cycles.
Your non-HPE code is executing 22 instructions more than the HPE code: 10 stores, 10 loads, and 2 ADDI to SP. And it is 48 bytes of code, as the loads and stores are 2 byte instructions, but the ADDIs exceed the range for 2 byte instructions and each use 4 bytes of code.
Assuming that code is always fetched at 4 bytes per cycle, regardless of whether it contains one 4-byte instruction or two 2-byte instructions, that 48 bytes of code accounts for 12 clock cycles of the 14 cycles difference.
So there is nothing very magical in the hardware stacking. It can load/store one register per cycle, while the software stacking need 3 cycles per 2 registers due to the instruction fetches (there is no icache).
BUT ... there is a flaw in your test.
Part of the point of using software stacking is that you only have to save and restore the registers you actually use.
Your code uses only a4 and a5, so those (plus ra) are all that actually need to be saved and restored. But the code is saving a0-a5 plus t0-t2.  Everything!
This is because you call the standard C function foo().  And so everything has to be saved, in case foo() nukes it.
I suggest you declare foo() also as __attribute__((interrupt)) and measure again. Oh, wait, crud, you can't just do that because it will end with mret not ret. We need something that is like __attribute__((interrupt)) but doesn't do that.
If the function is simple (doesn't create a stack frame) then jam an asm volatile ("ret") into it as well.
« Last Edit: March 31, 2023, 09:56:15 am by brucehoult »
No flaw, the test intentionally saves all registers. :) I did say it was supposed to be a worst-case scenario. I wanted to make it an apples-to-apples comparison - that each case was doing the same work. The docs say HPE saves 10 registers, so make the other case do the same.
I might do some more testing tomorrow with a best-case where the software-only version saves only a couple of registers (i.e. eliminate the function call). I'm sure the difference will be negligible, or even in favour of non-HPE.
« Last Edit: March 31, 2023, 10:37:20 am by HwAoRrDk »
Offline brucehoult
OK, fair enough.
And you got 0.58 µs difference at 24 MHz, and uliano got 0.44 µs difference at 48 MHz.
Prediction:
EXTI7_0_IRQHandler:
    addi sp,sp,-16
    sw a4,12(sp)
    sw a5,8(sp)
    lui a5,0x40011
    li a4,4
    sw a4,16(a5)
    lui a5,0x40010
    li a4,-1
    sw a4,1044(a5)
    lw a4,12(sp)
    lw a5,8(sp)
    addi sp,sp,16
    mret
0.6 µs at 24 MHz.
If you compile your main program with -ffixed-a4 -ffixed-a5 (which is of course likely to make main program code a little bigger and slower) then you can cut the interrupt routine down to (NOT using WCH fast interrupt mode)
EXTI7_0_IRQHandler:
    lui a5,0x40011
    li a4,4
    sw a4,16(a5)
    lui a5,0x40010
    li a4,-1
    sw a4,1044(a5)
    mret
This is a little bit expensive on RV32E with just 16 registers, but on RV32I with 32 registers you can easily partition off a few registers for use only by interrupt code with almost no effect on performance of the main program.
« Last Edit: April 01, 2023, 12:15:50 am by brucehoult »
Prediction:
0.6 µs at 24 MHz.
Close, but no cigar. :) It came out to 0.746 us with no sub function call.
The ISR assembly was as follows:
0000020a <EXTI7_0_IRQHandler>:
 20a: 1161                addi sp,sp,-8
 20c: c23a                sw a4,4(sp)
 20e: c03e                sw a5,0(sp)
 210: 4711                li a4,4
 212: 400117b7          lui a5,0x40011
 216: cb98                sw a4,16(a5)
 218: 400107b7          lui a5,0x40010
 21c: 40078793          addi a5,a5,1024 # 40010400 <__global_pointer$+0x2000fc00>
 220: 577d                li a4,-1
 222: cbd8                sw a4,20(a5)
 224: 4712                lw a4,4(sp)
 226: 4782                lw a5,0(sp)
 228: 0121                addi sp,sp,8
 22a: 30200073          mret
So faster than with HPE, but not by as much as you predicted - only 124 ns. I see your predicted code has one less instruction (no addi in constructing the 2nd register's base address), but that would only account for 0.042 us less at 24 MHz.
I estimate that the cross-over point, where using HPE gains you shorter ISR latency, as having 4 or more registers being saved/restored.
The take-away here seems to be that it is indeed faster not to use HPE in some scenarios - namely where the code doesn't call any other functions and is short and simple enough not to use more than 3 registers. But in other scenarios, HPE brings some benefit to interrupt latency.
Offline brucehoult
Sounds reasonable. The crossover will be even lower at 48 MHz -- you might not even get any gain to avoiding HPE at 2 registers, and it is hard to imagine an ISR that doesn't need at least 2.
Thanks for running the tests!
I've got the 003 kit, but it's sitting unopened at the moment. What I've been playing with today is at the other end of the RISC-V spectrum at the moment: an SG2042 machine with 64 2.0 GHz OoO THead C910 cores, each with dual vectpr pipelines with 256 bit ALUs. Each core is maybe 20% faster than those in a Pi 4 (mostly because of the extra MHz), but it has 16x as many cores :-)
Offline jnk0le
BTW, with Xtightlycoupledio this entire test sample would be just two `tio.addi` instructions (and isr return). No registers used.
https://github.com/jnk0le/XTightlyCoupledIO
Offline SiliconWizard
 :o
Offline langwadt
don't know much about risc-v but depending on hardware and memory, on some architectures it could also mean stacking, fetching a vector address and first ISR instructions could also be done in parallel, an cortex-M4 does that
Offline brucehoult
This is not a question of RISC-V, but of the size and complexity of the CPU core. Cortex-M4 is a couple of steps up from this core which is more on a level with M0.
I'd assume that this very low end core can't do two memory operations at the same time e.g. write a register to RAM at the same time as reading an instruction from flash.
The most basic RISC-V interrupt handling mode simply switches execution mode to M (but this chip only has M anyway), disabled interrupts, saves the old execution mode and interrupt enable status, saves the PC to MEPC, puts exception/interrupt number and associated data into special CSRs, and copies MTVEC to PC.  That's all in 1 cycle. The CPU then simply does the same as for any branch instruction, fetching and executing the instruction at the new PC which on a typical low end core has 1 instruction fetch wait cycle.
If you use the original vectored mode then PC is MTVEC + 4*cause, it takes typically 2 cycles to fetch and execute the jump instruction in the handler table, and 2 cycles more to execute the first instruction in the actual handler. This imposes a minimum of complexity and circuitry on the core (no state machine is needed other than the usual instruction fetch mechanism).
A more advanced vectored interrupt mode stores the address of the handler in the interrupt vector table. This is a couple of cycles faster and allows the interrupt handler to be anywhere in the address space, but it adds complexity to the core for not all that much gain.
Offline langwadt
yeh, it seems like for ARM only M3  and up is harvard
It would appear that the latter is what the WCH-supplied startup assembly code configures the CH32V003 to do. At least, that's what my interpretation of the assembly code is. It stores the address of a default dummy interrupt handler in the vector table, configures the MODE0 & MODE1 bits of mtvec to both be 1. All the default interrupt handler labels are declared as 'weak' so they can of course be overridden in user code.
_start:
.option   norvc;
    j       handle_reset
    .word   0
    .word   NMI_Handler                  /* NMI Handler */
    .word   HardFault_Handler            /* Hard Fault Handler */
    /* ...etc... */
    .word   TIM2_IRQHandler            /* TIM2 */
NMI_Handler:              1: j 1b
HardFault_Handler:        1: j 1b
/* ...etc... */
TIM2_IRQHandler:          1: j 1b
    la t0, _start
    ori t0, t0, 3
    csrw mtvec, t0
This reminds me - I wonder if anyone can explain this: I have noticed a weird thing when looking at the disassembly of compiled code for the default dummy interrupt handlers. They are just a simple infinite loop, comprised of a single jump instruction back to themselves. But, for some of the default handlers, the compiler emits multiple jump instructions, despite there only being a single one in the startup assembly code.
For example:
000002ea <DMA1_Channel7_IRQHandler>:
     2ea: a001                j 2ea <DMA1_Channel7_IRQHandler>
000002ec <ADC1_IRQHandler>:
     2ec: a001                j 2ec <ADC1_IRQHandler>
     2ee: a001                j 2ee <ADC1_IRQHandler+0x2>
     2f0: a001                j 2f0 <ADC1_IRQHandler+0x4>
     2f2: a001                j 2f2 <ADC1_IRQHandler+0x6>
000002f4 <SPI1_IRQHandler>:
     2f4: a001                j 2f4 <SPI1_IRQHandler>
Obviously, for ADC1_IRQHandler here, anything following the first instruction is redundant, and pointless to be there. What I think is going on here is that, in the case of ADC1_IRQHandler, is that these additional instructions are 'leftovers' from the dummy default handlers for other interrupts for I2C and UART which are normally between the ADC and SPI handlers. In this instance, I have my own ISRs defined for I2C1_EV_IRQHandler, I2C1_ER_IRQHandler, and USART1_IRQHandler, which correlate with the 3 excess instructions.
Why can't the compiler/linker get rid of this redundant code? Is it because it doesn't realise that, once the 'weak' reference is overridden, that these instruction don't actually belong to the nearest preceding label? Is there any way we can tidy this up?
As far as I understand, the way the linker omits unused code is via the -ffunction-sections option, so could something be done to put each default dummy interrupt handler into its own section, so that the linker knows to omit ones that have been overridden?
Offline brucehoult
-ffunction-sections is an option for the C compiler, to make a different section for each function.
In assembly language you make your own sections regardless, so if the source doesn't do that then it's all one big section for the default handlers.
The linker can't just go mucking about deleting stuff from the INSIDE of a section.
Silly me, I mis-remembered - I was thinking of --gc-sections.
So, could it work if one were to put each default interrupt handler in its own section?
I note that they are all currently put in a section called .text.vector_handler, but what if one were to do the following?
.section .text.vector_handler.NMI_Handler
.section .text.vector_handler.HardFault_Handler
/* ...etc... */
.section .text.vector_handler.TIM2_IRQHandler
Then the linker would be able to (with --gc-sections specified) recognise any overridden default interrupt handlers and exclude them from the compiled binary, right? Thus saving space by omitting redundant code.
BTW, I can't quite figure out what the flags and type argument are on the default section directive for the 'vector_handler' section: .section  .text.vector_handler, "ax", @progbits. What is an 'allocatable' section ('a' flag), and why does it need to marked with '@progbits' (meaning "section contains data")?
Offline brucehoult
That looks like it should work. Might want to check the linker script to see if it will gather the (non GCd) handler sections together .. if you care. On a CPU without cache it's probably not important.
The principle seems to work. :-+ Or, at least, it compiles and links apparently fine. I would need to actually test running the resultant code on physical hardware.
If I list each default dummy interrupt handler like as follows (using the same section name as a user-implemented ISR function section would get):
.section .text.NMI_Handler, "ax", @progbits
.weak NMI_Handler
Then there is no redundant code emitted for handlers that are overridden.
For instance, if I have a user-implemented handler for EXTI7_0_IRQHandler, whose default dummy handler normally resides between the RCC and AWU handlers, I get the following:
000000ae <RCC_IRQHandler>:
  ae: a001                j ae <RCC_IRQHandler>
000000b0 <AWU_IRQHandler>:
  b0: a001                j b0 <AWU_IRQHandler>
No extra redundant code at the tail end of RCC_IRQHandler. :) And the ISR from my code appears further on as expected:
00000208 <EXTI7_0_IRQHandler>:
 208: 1161                addi sp,sp,-8
 20a: c23a                sw a4,4(sp)
 20c: c03e                sw a5,0(sp)
 20e: 4711                li a4,4
 210: 400117b7          lui a5,0x40011
[...etc...]
All of this is of course nitpicking with regard to wasted space, as you'd probably be saving at most a few dozen bytes of space, but when you only have 16 kB to play with, it could make all the difference. ;D
Offline brucehoult
If you want to hunt down every byte then having a different infinite loop for each default handler is a waste. Unless you actually do get an unexpected trap and connect with a debugger to see exactly which infinite loop you are in.
Also, I seen to remember something zeroing all the registers on startup. There shouldn't be any code relying on that so it could go.
Offline langwadt
the stm cube startup code uses .thumb_set to alias all the all different handler names with a single default_handler
Offline brucehoult
It's not a problem to put all the default handler labels one after another with a single j . following them instead of one each. It just loses information in the event one of them gets called unexpectedly. Not totally, as you can check the mcause CSR in the debugger if need be.
No, their startup code doesn't have any register zeroing. But I have seen that in other startup code (I think it was some guy's recent article on using Rust on CH32V); just a long train of mv xN, zero instructions for x1 through x15.
Are RISC-V CPU registers not guaranteed to be zero at reset then? But yes, I would imagine it is a rare case that would have problems without that.
That's neat. If it's possible to determine which interrupt/exception it was with mcause, one wonders why they bothered wasting space with separate default handlers at all.
Offline brucehoult
I don't think there is anything in the ISA spec saying anything about initial values. Individual core designers might well zero on reset -- maybe even most of them. I think it would be bad coding practice for code to depend on either the hardware or the start code doing it.
Well, sure it's possible. Many setups use a single handler for all exceptions, put register save/restore in a single location, implement features such as late preemption by a higher priority interrupt coming in during register stacking for lower priority interrupt, interrupt chaining etc. Then at some point you do have to figure out what the interrupt was and dispatch to the correct handling for it.
I guess if you wanted to do that you would do so with the mtvec mode setting where it will always just jump to the specified base address on interrupt, rather than base+4*N.
There isn't as far as I remember. And I've rarely seen any piece of code relying on that on any CPU. That would sound odd.
Of course we're talking about general-purpose registers here.
The PC and a few other dedicated registers are of course initialized to a known value upon reset, not necessarily zero either.
There is a vectored mode in the RISC-V ISA.
Of course, many actual implementations add their own interrupt controller (which is one of the reasons they often need a patched compiler), which can make things more efficient than the base exception/interrupt modes.
In my own rendition of an interrupt controller, it does directly set the PC to the corresponding handler address stored in a dedicated table only accessible by the interrupt controller. It's faster and more secure. But there are plenty of other approaches out there.
Offline brucehoult
I'm not sure what this adds to the discussion?
The ENTIRE THREAD has been about a RISC-V vectored interrupt mode.
The message you replied to is pointing out that there is ALSO a NON-vectored mode. which is used by many systems, especially those running Linux or similar on >1 GHz CPUs, where you don't care about shaving nanoseconds off the interrupt response times and you usually have some simple 32 or 64 bit auxiliary CPU core to handle real-time tasks.
Possibly nothing? ;D
But if that helps, I think my point may have not been very clear.
There is a vectored mode in the RISC-V ISA, *but* you still need to read the xcause register to figure out if this is an interrupt or an exception.
And use exception codes >= 16 (at least if I understand the specs correctly) for your custom interrupt sources, if you want vectored interrupt handlers - otherwise the basic approach is to use the external interrupt code and then read the interrupt source from some register in your interrupt controller, not the most efficient.
But vendors do implement interrupt controllers in various ways, more or less deviating from the base exception mechanism.
I remember a talk from Krste Asanovic himself about fast interrupt handling, if that can be of any interest to anyone. Can be found easily on YT.
Sure,  but the part I was actually replying to didn't make it obvious you were talking about very fast systems when the whole topic was about MCUs.
And on a MCU running at a few tens of MHz, having to check the interrupt flag in xcause, then test against the exception code and execute code based on that when you have a number of possible interrupt sources, that sure wouldn't be insignificant.
