So the guy needs a 101 primer on concepts of control theory
GOD don't go there, he retires in under a year and as much as I like him I'll almost be relieved, to him everything is an input or an output, or it has a "switching action". The classic was when I tried to explain the feedback mechanism of a position potentiometer in the water valve, I had to explain each pin, the worrying bit was when he asked if the pot ground was an input or an output, I just wanted to run.
He also thinks that if i put spike suppression on the positive line, i need on on the negative (vehicle chassis too)
