Author Topic: Is it possible to convert STM8 hex to C code?  (Read 1368 times)
Offline ChrissTopic starter
« on: December 07, 2019, 01:20:51 am »
Hi!
I have a battery charger with an STM8S003F3 in there.
I would like to change a startup function and add a reset/restart button function.
I know, I could add the reset manually on the pcb too, but just for fun I would poke around the firmware.
Is it possible to convert the firmware from this uC to C/C++ code if I read out the content?
Thanks.
Offline thm_w
  • Non-expert
Re: Is it possible to convert STM8 hex to C code?
« Reply #1 on: December 07, 2019, 01:38:28 am »
No, not in any way you would want. Try reading out the code first then go from there.
https://stackoverflow.com/questions/42166539/microcontroller-stm8-disassembly
The following users thanked this post: Chriss
Online ataradov
    • Personal site
« Reply #2 on: December 07, 2019, 01:57:15 am »
It is impossible automatically. However, it is an 8K device, and the real HEX size is probably less. If you know what you are doing, you can reverse that in a couple days.
Alex
