Author Topic: SiLab 8051F410 programmer  (Read 5171 times)
Offline blueagle91Topic starter
« on: August 15, 2016, 08:06:50 pm »
So hello eevryone,
I received an 8051F410 from SiLabs, and all is fine but im new with 8051, and my problem is how to make a cheap programmer for this guys.
Any idea, i tried to find something on net but either i typed the wrong search quote or it is hard to find.
So simply is there any simple programmer for these 8051, something you could build easily. Im ok with SMD work.
Thanks all the best.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: SiLab 8051F410 programmer
« Reply #1 on: August 15, 2016, 08:16:22 pm »
Their debugger programmer is one of the cheapest. Why spend hours when you can simply buy one for 30$?
http://nl.farnell.com/silicon-labs/debugadptr1-usb/adaptor-usb-debug-for-c8051fxxx/dp/1186943
Offline amyk
« Reply #3 on: August 16, 2016, 02:09:54 am »
https://www.silabs.com/Support%20Documents/TechnicalDocs/an127.pdf
That and the last 5 pages of the C8051F410 datasheet should be enough.
« Reply #4 on: August 21, 2016, 01:02:35 pm »
Sry for not responding too hastly, thanks guys. Yeah i found all of those, i thought maybe there is something to build fast and to try it. Cause i want it now :D
But hey ill have to wait for the post :) Thanks guys all the best
