also the following doesn't work under ghdl
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
constant XLEN : integer := 32;
subtype cpuWord is std_logic_vector(XLEN -1 downto 0);
when alu_add =>
res <= opa + opb + (getStdLogicVectorZeroes(XLEN-1) & cin);
those libraries are NOT defined in ghdl and can't be used easily
therefore the "+" operator is not defined for std_logic_vector
and the attempt to simulate "opa + opb" will result an error
instead you need to use
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
along with the following ugly code
when alu_add =>
result <= std_logic_vector
unsigned(opa) + unsigned(opb) +
unsigned(getStdLogicVectorZeroes(XLEN-1) & cin)
work <= std_logic_vector
unsigned("0" & opa) + unsigned("0" & opb) +
in this case "unsigned(opa) + unsigned(opb)" is allowed
because the "+" operator is defined along with unsigned
but the result needs to be std_logic_vector
both the above pieces of code come from OpenCores
therefore I assume it's a common trouble
edit:
entity ALU_arithmetic is
Port
enable : in std_logic;
opa : in cpuWord;
opb : in cpuWord;
